Fireface UCX
36-Kanal, 24-Bit/192kHz High-End USB & FireWire Audio Interface
Fireface UCX
Produkte
Fireface UCX
Das Fireface UCX ist eine hoch integrierte Pro-Audio Lösung in einem ultra-kompakten Format, für Studio- wie Live-Betrieb. Es steht in der langen RME-Tradition ultra-kompakter High-End-Interfaces, die in einem Halb-19-Zoll-Gehäuse Features, Funktionalität und Qualität vereinen, für die andere Hersteller mehrere volle Rackbreiten benötigen.
How to win the Latin Grammy Award with RME’s Fireface UCX
Artists
I am a recording and mixing engineer who has worked in Venezuela for more than 30 years. I studied at New York´s Institute of Audio Research ...
Mehr Informationen
How to “mix in a bus” with RME’s Fireface UFX
Artists
Soundesign Ltd. provides broadcast sound for radio, TV, film and music productions. To service this market they have built the Mixbus,...
Mehr Informationen
Mr. Barrington's Hip Hop & Electronica sound makes the Fireface UCX a perfect fit
Artists
With an inspired blend of soaring melodies and daring musicianship, Mister Barrington's music has been described as a lovechild combo ...
Mehr Informationen
Purity Ring
Artists
Purity Ring
The ultra-low latency of RME interfaces and complex routing options of the Total Mix software are integral to our live setup.
Mehr Informationen
“Recording the renowned drummer Kuniko”  - Drummer to Percussionist
Artists
The recording sessions are for Kuniko's 4th coming global release from LINN Records titled Works for Bach vol.1 (tbd.).
Mehr Informationen
Anschlüsse und Features
8 x Analog I/O
2 x XLR/TRS Mic/Inst/Line
2 x Line/Inst Input
1 x Phones Output
1 x SPDIF I/O
1 x ADAT I/O
1 x Word Clock I/O
2 x MIDI I/O
FireWire or USB operation
Class Compliant Mode
TotalMix FX
ARC USB
RME USB 2.0
AutoSet Digital Gain Control
DC-coupled Outputs (Phones)
Including FX
Auf dem Weg dorthin war ein neuer Rekord notwendig: das UCX integriert nochmals 300 Elektronikkomponenten mehr, als das bereits dicht am Limit vollgepackte Fireface UC.
Das Resultat ist eine atemberaubende Kombination aus RMEs erfolgreichsten Interfaces: Fireface UFX, Fireface 400/UC und Babyface. Dabei ist das Fireface UCX nicht nur eine kleinere Ausgabe des UFX, inklusive HFX-Core und der kompletten 192 kHz Effektengine. Mit diesem technischen Generationssprung setzt es einen neuen Meilenstein in der langen Reihe der erfolgreichen, kompakten RME-Interfaces und fügt obendrein dank der optionalen Advanced Remote Control die großartige Benutzererfahrung des Babyface hinzu.
TotalMix FX DSP Effects
TotalMix FX beinhaltet ein komplettes Effekt-System: EQ, Reverb, Dynamik & Delay
Die Ausstattungsmerkmale des Fireface UCX im Überblick:
  • Low Latency Wandler der Masteringklasse mit überragenden Spezifikationen
  • Zwei Mic Preamps mit der Premium Technologie der Hi-End Bestseller Micstasy und UFX, einschliesslich AutoSet Übersteuerungsschutz.
  • Ein neu entwickelter Hammerfall Audio Core, der maximale Performance und niedrigste Latenz bei USB und FireWire bietet, kombiniert mit der legendären Treiberstabilität und -Pflege, für beide Busprotokolle.
  • TotalMix FX mit der kompletten 192-kHz-Effekt-Engine des Fireface UFX
  • Monitoring Controller: kombiniert die beeindruckende Flexibilität des TotalMix FX Monitor Controllers mit der optionalen RME Advanced Remote Control.
  • RMEs einzigartiges Meter- und Analyse-Werkzeugset DIGICheck.
  • Ausserdem aktive Jitterunterdrückung, professionelle Referenzepegel, erweiterte Standalone-Funktionalität, vollständiger Betrieb mit 192 kHz, und natürlich zwei High-Speed MIDI I/Os.
  • Und oben drauf: Das Fireface UCX ist das erste, voll professionelle Audio-Interface mit einem Class Compliant Modus. Es lässt sich an Apples iPad anschließen, erweitert dieses um perfektes Stereo- und 18-Kanal Playback/Recording, sowie professionelle I/Os in überragender Qualität.
Alles in allem ist das Fireface UCX ein echtes 'Dream'-Interface, entwickelt mit Liebe zum Detail. Die neue Premium-Lösung für jeden Desktop als auch Live, ohne Kompromisse bei Klang, Stabilität oder Low-Latency-Betrieb.
Eingänge und Ausgänge
Das UCX bietet 36 Audiokanäle - 18 I/Os. Alle Kanäle können gleichzeitig genutzt werden. Bis zu 8 analoge und 10 digitale Kanäle können auf 18 Spuren aufgenommen werden. Alle Ausgänge sind selbstverständlich für ASIO Direct Monitoring nutzbar.
Verfügbare Kanäle in Abhängigkeit zur Samplefrequenz:
Samplerate Analog SPDIF ADAT Gesamt
44.1/48 kHz 8/8 2/2 8/8 18/18
88.2/96 kHz 8/8 2/2 4/4 14/14
176.4/192 kHz 8/8 2/2 2/2 12/12
Analoge I/Os
Das Fireface UFX besitzt 8 sehr flexible analoge I/Os:
8 Eingänge
Auf der Rückseite: 4 x symmetrische Klinke. Auf der Frontseite: 2 XLR-Eingänge mit Mic/Line-Vorverstärkern (65 dB Gain) plus 2 Hi-Z-fähige Line/Instrumenten-Klinkeneingänge.
8 Ausgänge
Auf der Rückseite: 6 symmetrische Klinkenausgänge. Auf der Frontseite: Ein Stereo-Kopfhörer-Ausgang (Wiedergabekanal 7/8), der hohe Lautstärken bei hoch- und niederohmigen Kopfhörern bietet.
Sound-Qualität
Ausgestattet mit einem neuen 2011 AD und DA High-Performance Wandlerdesign unterstützen alle I/Os Sampleraten von bis zu 192 kHz. Die AD/DA-Wandlung übertrifft sogar die außergewöhnlichen technischen Spezifikationen des Fireface UC/400 mit einem eindrucksvollen Dynamikbereich von 114 dBA für Aufnahme und Wiedergabe. Die fortschrittliche Multi-Bit Wandler-Architektur garantiert außergewöhnlich niedrige Rausch- und Verzerrungswerte über einen großen Pegelbereich. Im Gegensatz zu anderen Herstellern setzt RME in der Klang- und Produktphilosophie konsequent auf die originale Abbildung des Ursprungssounds. Ein RME-Interface fügt dem Originalklang nichts hinzu und nimmt ihm nichts weg, vielmehr fängt es den Originalklang unverfälscht ein.
Auch im UCX sorgt die integrierte RME SteadyClockTM durch effiziente Jitterunterdrückung für eine optimale AD/DA-Wandlung, selbst bei Taktung von einer externen Clockquelle.
Low Latency Wandler
Alle analogen I/Os basieren auf einem Low-Latency Wandlerdesign mit beeindruckenden 14 Samples für die AD-Wandler, und 7 Samples für die DA-Wandler, unabhängig von der genutzten Samplerate. Diese Werte betragen nur ein Viertel der Werte des Fireface UC/400 (43/28), und überflügeln auch Geräte die ein Vielfaches kosten. Ein technischer Durchbruch, der die Gesamtlatenz timingkritischer Anwendungen in Live-Situationen und in Computer-basierten Studios weiter reduziert. Die Wandler-Latenz ist so gering (0,4 ms bei 48 kHz), dass sie praktisch ignoriert werden kann, und analog-digitales Monitoring zu reinem Analog-Monitoring aufschließen lässt.
Professionelle Referenzpegel
Überragende Wandler erfordern die Unterstützung verbreiteter Studiopegel für eine perfekte Anpassung an anderes analoges Studio-Equipment. Wie alle anderen RME-Interfaces unterstützt das UCX die professionellen Studiopegel -10 dBV, +4 dBu, Lo / HiGain. Die per Software einstellbaren Referenzpegel, als diskrete Schaltung in Hardware realisiert, garantieren vollen Dynamikbereich und exzellente Signalqualität.
- Eingänge 3 - 8: -10 dBV, +4 dBu und Lo Gain (einstellbar in zwei Gruppen - Kanäle 3/4 und 5 bis 8).
- Ausgänge 1 - 8: -10 dBV, +4 dBu und Hi Gain (einstellbar in zwei Gruppen - Kanäle 1 bis 6 und 7/8).
RME Audio Fireface UCX
36 Audiokanäle in einem halben 19-Zoll-Gehäuse mit voller mobiler Nutzbarkeit.
Qualität statt Quantität
Das UCX verfügt über zwei Hi-End Mikrofon- und Instrumenten-Vorverstärker - direkt zugänglich auf der Frontseite. Wie im UFX nutzen beide Preamps die Technologie des RME Micstasy, eines Hi-End Vorverstärkers für außergewöhnliche klangliche Anforderungen und kritische Anwendungen, wie die professionelle Aufzeichnung klassischer Konzerte. Das außergewöhnliche Design beeindruckt durch extrem niedrige Verzerrungs- und Rauschwerte, sowie einen extrem linearen Frequenzgang. Damit entsteht eine herausragende Lösung zur unverfälschten Übertragung und Verstärkung jeglicher Signale, seien es hochpegelige Bühnen-, oder typische Studiosignale, niederpegelige oder hochohmige Instrumente, dynamische oder Bändchen-Mikrofone.
Die digital kontrollierte Verstärkung von bis zu 65 dB, einstellbar in Schritten von 1 dB über einen Bereich von 55 dB, wird individuell für jeden Eingang über TotalMix FX oder den Drehknopf auf der front eingestellt. Alle Einstellungen sind 100% reproduzierbar und auch per MIDI ferngesteuert einstellbar.
48V Phantomspeisung ist pro Kanal individuell schaltbar. LEDs für Signal, Clip und aktivierte Phantomspeisung geben einen Überblick über den Status des Gerätes.
Die beiden Stereo-Klinken-Eingänge auf der Front sind wahlweise als Instrumenteneingänge nutzbar. Ob zwei Gitarren oder Keyboards - es ist keine weitere Hardware erforderlich.
AutoSet
Das UCX verfügt zudem über ein einzigartiges RME-Feature, dass zuvor nur im High-End-Preamp Micstasy und im UFX enthalten war. Einige Preamps enthalten Limiter, mit denen eine Übersteuerung - insbesondere des AD-Wandlers - vermieden werden soll. Eine solche Schaltung würde allerdings die hervorragenden technischen Daten des Mic-Frontends beeinflussen.
Dank des komplett digital kontrollierten Gains kann das UCX den Gain auch selbst einstellen. Damit ergibt sich ein perfekter Übersteuerungsschutz ohne jegliche Verschlechterung, Rauschen, Kompression oder Pegelspitzenreduktion des Nutzsignales, da dieses keine zusätzliche analoge Elektronik durchlaufen muss.
Beispiel: Während einer Recording-Session fordert der Toningenieur den Sänger oder Gittaristen auf, einen lauten Referenzteil zu singen oder zu spielen. Zuvor stellt er die Vorverstärkung am UCX auf einen sehr hohen Wert (z. B. 50 dB). Mit aktiviertem AutoSet wird nun das Signal, sobald es -6 dBFS erreicht, basierend auf der Intensität und Dauer, automatisch reduziert. Damit werden manuelle Eingriffe während einer Performance weitgehend überflüssig, sind aber selbstverständlich jederzeit möglich. AutoSet kann für jeden der vier Mic/Instrument-Preamps auf der Frontseite separat aktiviert werden.
Digitale I/Os, Wordclock & MIDI
SPDIF
Das UCX verfügt über einen koaxialen SPDIF I/O, der mit bis zu 192 kHz Samplefrequenz arbeitet.
ADAT
 Ein 8-kanaliger ADAT-I/O erlaubt den Anschluss eines externen Wandlers, eines Mixers oder Effektgerätes. Die Ports arbeiten mit bis zu 192 kHz, mit der von ADAT bekannten Einschränkung auf 2 Kanäle (SMUX/4). Wie auch bei SPDIF sind die 8 ADAT-Kanäle simultan verfügbar. Die Nutzung eines externen Konverters, wie dem ADI-8 QS, ergibt beim UCX 16 analoge Eingänge und Ausgänge, 12 bei einer Samplefrequenz von 96 kHz, und immer noch 10 bei 192 kHz.
SPDIF
Der ADAT-Port dient optional als optischer SPDIF I/O, was das UCX in den Anschlüssen noch flexibler macht.
Wordclock & MIDI
Ein Wordclock I/O (BNC) mit schaltbarer Terminierung und zwei MIDI I/Os komplettieren die verfügbaren Anschlüsse und machen das Fireface UCX zu einem professionell und universell nutzbaren Audiosystem.
TotalMix FX -Mixing / Routing mit überragenden Funktionen für Studio und Live Anwendungen
Seit 2001 erweitert TotalMix die Audio-Interfaces von RME um unbegrenztes Routing und Mixing. Seine einzigartige Fähigkeit, so viele unabhängige Submixe zu erstellen, wie Ausgangskanäle zur Verfügung stehen, machte es zum flexibelsten und leistungsfähigsten Mixer seiner Art.
Erfahren Sie mehr
DigiCheck - Die Geheimwaffe für hochauflösende Audiomessverfahren
RMEs einzigartige Software-Toolbox zum Testen, Messen und Analysieren digitaler Audio Signale. 2, 8 oder alle Kanalpegelmesser mit unzähligen Optionen. Spektralanalysator, Goniometer und Bitstatistik in professioneller Qualität.
Download DigiCheck für RME Audio Interfaces
Das Fireface UCX ist das erste wirklich professionelle Audio-Interface mit integriertem Class Compliant Modus.
Dieser Begriff beschreibt einen Standard, der nativ von Betriebssystemen wie Windows, Mac OS X und Linux unterstützt wird. Es sind dann keine weiteren Treiber erforderlich, das Gerät wird direkt erkannt.
Darüber hinaus erlaubt der Class Compliant Modus auch den Anschluss des UCX an beliebige Apple iPadTM !
Das iPad ist nicht nur eine attraktive mobile Musik Kreation- und Recording-Plattform, sondern auch ein geschlossenes Hard- und Software-System, ohne die üblichen Treiberprobleme und Störungen durch Fremdhardware, wie Grafik- oder Netzwerkkarten. Das System ist stabil, bietet eine gute Echtzeit-Perfomance und eine einfache Bedienung.
Das UCX stattet das iPad mit den analogen professionellen I/Os aus, die ihm standardmäßig fehlen. Hochwertigste Mikrofon-Preamps mit EQ, Dynamics, selbst AutoSet, dazu professionelle symmetrische Line-Ausgänge und ein Hi-Power Kopfhörerausgang, der auch mit hochohmigen Phones überzeugt. Plus Pegel- und Gainanpassungen, SPDIF/ADAT I/O, Hall, Echo und Zero Latency Monitoring. Dies alles digital über USB, also in uneingeschränkter Qualität mit bis zu 96 kHz und 24 Bit. Und natürlich ein doppelter, Sysex-fähiger MIDI I/O.
Das UCX bietet hier noch eine Besonderheit: es arbeitet am iPad nicht mit der verjitterten USB-Clock, sondern mit seiner internen SteadyClock. Viele USB-Audiogeräte extrahieren die Clock für die DA-Wandlung aus den USB-Datenpaketen, und sind damit in einem vergleichsweise verjitterten Slave-Modus (Adaptive Mode). Insbesondere da sie normalerweise auch keine aktive Jitterunterdrückung im Audiobereich bieten. Das UCX arbeitet dagegen als Clock Master (Asynchronous Mode), bei Aufnahme wie Wiedergabe, und erreicht damit am iPad die exakt gleiche Klangqualität wie unter Windows oder Mac OS X.
Unterstützte Eingänge und Ausgänge . Am iPad funktioniert bei Mono-Apps Eingang 1, bei Stereo-Apps Eingang 1/2 (also Mikrofon/Line, sowohl Dual-Mono als auch Stereo), und bis zu 8 Eingänge bei Apps wie MultiTrack DAW und Music Studio. Garage Band unterstützt alle Eingänge, aber nur zwei gleichzeitig. Auria kann alle 18 Eingänge gleichzeitig aufnehmen.
Bei der Wiedergabe arbeiten die rückseitigen analogen Ausgänge 1 und 2, oder auch mehr, wenn die jeweilige App das unterstützt. Das UCX kann wahlweise die iPad Playback-Kanäle 1/2 auf die Ausgänge 7/8 und SPDIF/ADAT kopieren, für vereinfachtes Monitoring. Alle Ausgänge können unabhängig prozessiert werden (Volume/EQ/Dyn/FX Return).
Audio-Routing und Processing
Das UCX ist also auch im Modus CC sehr leistungsfähig, und lässt sich sogar per TotalMix FX unter Windows/Mac für den CC-Betrieb vorkonfigurieren. Neben der aktuellen Einstellung lassen sich bis zu 6 Konfigurationen im Gerät speichern und sehr schnell aufrufen.
Das Eingangssignal durchläuft sämtliche aktivierten Funktionen des TM FX Eingangskanals, also Settings, EQ und Dynamics, und wird dann zum iPad gesendet. Wie auch unter Windows/Mac lässt sich mittels Routing zu den Ausgängen 1/2 und 7/8 über den Input-Fader ein direktes Monitoring einstellen. Auch der Send-Regler für Echo/Reverb ist aktiv. Das Ausgangssignal des iPad durchläuft sämtliche aktivierten Funktionen des TM FX Hardware Outputs, also Settings, EQ und Dynamics. Der Fader in der dritten Reihe stellt den Ausgangspegel ein.
SteadyClock
RMEs einzigartige SteadyClock-Technologie des Fireface UCX garantiert exzellentes Verhalten in allen Clock-Modi. Aufgrund der effizienten Jitterunterdrückung arbeiten die AD- und DA-Wandler des UCX immer optimal, vollkommen unabhängig von der Qualität der Referenzclock, und garantieren damit eine perfekte Klangqualität.
Dank SteadyClock kann das UFX seine Samplefrequenz selbst frei bestimmen. Der Settingsdialog erlaubt eine direkte Anwahl der für Audio und Video gebräuchlichsten Samplefrequenzen.
DIGICheck
Das UCX beinhaltet DIGICheck, RME's unübertroffenes digitales Audio Analyse Tool. Vom Multitrack-Recorder über die Spektral-Analyse bis zum ausgefeilten Level Metering bietet DIGICheck einzigartige Funktionen und Merkmale. Es zeigt ausserdem die in Hardware berechneten Pegeldaten an, und kann sogar die Wiedergabedaten einer Audiosoftware direkt anzeigen.*
ICC
Intelligent Clock Control zeigt nicht nur den Status aller Clocks, sondern hält auch die letzte gültige Samplefrequenz im Falle eines Ausfalls der externen Quelle. Die von anderen RME-Produkten bekannten und bewährten Technologien wie SyncCheck sorgen für eine leichte Erkennung von Fehlerzuständen.
Stand-Alone Betrieb mit Setup Recall
Das UCX enthält sechs interne Speicherplätze zum dauerhaften Ablegen aller Konfigurationsdaten. Damit arbeitet es auch ohne Rechner vollständig autark, und verwandelt sich im Stand-Alone Betrieb, also ohne angeschlossenen Rechner, auf Knopfdruck in verschiedenste, unterschiedlichste Geräte. Darüber hinaus kann TotalMix auch im Stand-Alone Betrieb per MIDI kontrolliert werden. Beispiele für Anwendungen sind: 8-Kanal AD/DA Wandler, 4-Kanal Mikrofon-Preamp, Monitor-Mischer, digitaler Format-Wandler, analoge/digitale Routing Matrix.
Zubehör
19" Rackmounts
Tech-Specs
Fireface UCX
AD, Line In 5-8, Rückseite
  • Rauschabstand (SNR): 111 dB RMS unbewertet, 113 dBA
  • Frequenzgang @ 44.1 kHz, -0,5 dB: 6 Hz - 20.6 kHz
  • Frequenzgang @ 96 kHz, -0,5 dB: 6 Hz - 45,3 kHz
  • Frequenzgang @ 192 kHz, -1 dB: -1 dB: 5 Hz - 90 kHz
  • THD: < -105 dB, < 0.0005 %
  • THD+N: < -98 dB, < 0,0012%
  • Maximaler Eingangspegel: +19 dBu
  • Übersprechdämpfung: > 110 dB
  • Eingang: 6,3 mm Stereoklinke, elektronisch symmetriert
  • Eingangsempfindlichkeit schaltbar Lo Gain, +4 dBu, -10 dBV
  • Eingangspegel für 0 dBFS @ Lo Gain: +19 dBu
  • Eingangspegel für 0 dBFS @ +4 dBu: +13 dBu
  • Eingangspegel für 0 dBFS @ -10 dBV: +2 dBV
Line In 3-4, Frontseite
Wie AD, aber:
  • Additional Gain-Stage: 0 bis +12 dB
  • Maximaler Eingangspegel, Gain 0 dB:
  • Line +19 dBu, Instrument +13 dBu
  • Maximaler Eingangspegel, -10 dBV, Gain 12 dB, Line:
  • -7,5 dBu, Instrument: -13,5 dBu
  • Eingangsimpedanz Instr.: 470 kOhm
  • Eingangsverstärkung Instr.: +6 dB
  • Eingangsmode: Line symmetrisch (Klinke), Instr. (Klinke)
  • CLIP LED: 0 dBFS
  • SIG LED: -60 dBFS
Mic/Line 1-2, Frontseite
Wie AD Line In 5-8, aber:
  • Eingang: Neutrik XLR/TRS Combo jack, electronically balanced
  • Eingangsimpedanz: XLR 2 kOhm, TRS 8 kOhm symmetrisch
  • Rauschabstand (SNR): 112 dB RMS unweighted, 115 dBA
  • Low Roll Off -0,5 dB: 18 Hz, -1 dB: 12 Hz
  • Regelbereich Gain: 0 dB, +10 up to +65 dB
  • Maximum Eingangspegel XLR, Gain 0 dB: +10 dBu
  • Maximum Eingangspegel XLR, Gain 65 dB: -55 dBu
  • Maximum Eingangspegel TRS, Gain +0 dB: +21 dBu
  • Maximum Eingangspegel TRS, Gain +65 dB: -44 dBu
  • CLIP LED: 0 dBFS
  • SIG LED: -60 dBFS
DA, Line Out 1-6, Rückseite
  • Rauschabstand (DR): 111 dB, 113 dBA @ 44,1 kHz (unbewertet)
  • Frequenzgang @ 44.1 kHz, -0,1 dB: 8 Hz - 20,4 kHz
  • Frequenzgang @ 96 kHz, -0,5 dB: 6 Hz - 45 kHz
  • Frequenzgang @ 192 kHz, -1 dB: 5 Hz - 90 kHz
  • THD: -100 dB, < 0,001 %
  • THD+N: -96 dB, < 0,0015 %
  • maximaler Ausgangspegel: +19 dBu
  • Ausgang: 6,3 mm TRS jack, servo-balanced
  • Ausgangsimpedanz: 75 Ohm
  • Ausgangspegel schaltbar: Hi Gain, +4 dBu, -10 dBV
  • Ausgangspegel bei 0 dBFS @ Hi Gain: +19 dBu
  • Ausgangspegel bei 0 dBFS @ +4 dBu: +13 dBu
  • Ausgangspegel bei 0 dBFS @ -10 dBV: +2 dBV
DA - Phones, 7/8, Frontseite
Wie DA, aber:
  • Ausgang: 6,3 mm Stereoklinke, unsymmetrisch
  • Ausgangsimpedanz: 30 Ohm
Wordclock
  • BNC, Schalter für interne Terminierung 75 Ohm
Zurück
Treiber
Fireface UCX
Mac OS X
Veröffentlichungsdatum
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and M1 machines. DigiCheck NG V 0.90 requires macOS 10.13 (High Sierra) or up.
2023-06-27
DIGICheck 0.73 Mac
2017-09-14
Download
dc_073_mac.zip
Windows
Download
DIGICheck 5.96 Win
2023-01-13
Download
dc_596_win.zip
Windows 10
Download
DigiCheck NG Windows
DigiCheck NG V 0.90 requires a Direct3D 12 capable graphics card and Windows 10 or up.
2024-05-08
Windows 11
Download
2024-05-08
Windows Vista
Download
DIGICheck 4.53 (Works with all RME cards, except HDSPe RayDAT and AIO)
Stereo Level Meter, Multichannel Level Meter, Global Level Meter, Spectral Analyser, Vector Audio Scope, Correlation Meter, Totalyser, Bit Statistic & Noise, Global Record. ASIO support, multi-client operation, display of +dBFS levels, display of playback data, K-system, free reference/scale, third colour. New: Hardware Level Meter. RMS Slow and RLB weighting filter. Optional Correlator. Level meters vertical/horizontal. Presets with hotkeys. Support for Fireface 400, newer Fireface 800 drivers, HDSP series WDM driver. Record functionality Global Record. Compatible to HDSPe PCI and HDSPe MADI/MADIface
2008-09-02
Download
dc_453.zip
Windows XP SP2
Download
2008-09-02
Download
dc_453.zip
Flash Update
Download
Mac OS Flash Update Tool for Fireface UFX, 802, UCX, UCX II, UC, Babyface/Pro
Update to version UFX: 361/163/344/29, 802 A: 20/9/9/12, 802 E: 112/101/101/9, 802 FS: 221/ 212/ 27, UCX: 49/260/27/14, UCX II (6): 43/34/21, UCX II (7): 106/34/104, UC: 127/138, Babyface: 226, Babyface Pro & FS: 206/320.
2024-05-03
Download
fut_usb_mac.zip
Windows Flash Update Tool for Fireface UFX, 802, UCX, UCX II, UC, Babyface Pro
Update to firmware revision UFX: 361/163/344/29, 802: 20/9/9/12 (A), 112/9/101/101 (E), 802 FS: 22/27/212, UCX: 49/260/27/14, UCX II (6): 43/34/21, UCX II (7): 106/34/104, UC: 127/138, Babyface: 226, Babyface Pro & FS: 206/320.
2024-05-03
Download
fut_usb_win.zip
Mac OS X
Download
2024-05-03
Download
fut_usb_mac.zip
macOS 11 and up USB Series Kernel Extension Driver
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.31. Supports Intel and Mx.
2024-01-17
macOS 11 or up USB Series DriverKit Driver+Fut
macOS 11 or up USB series DriverKit driver, v. 4.09.
2024-01-17
macOS 10.12 up to 10.15 driver for Fireface UFX / UFX+ / UFX III, UFX II, 802, UCX, UCX II, UC, Babyface, Babyface Pro, MADIface XT/USB/Pro, Digiface USB/AES/Dante/Ravenna
version 3.223. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. Mx users please download macOS 11 and up USB Series Driver.
2024-01-16
Mac OS X driver for Fireface UFX / UFX+ / UFX II, 802, UCX, UCX II, UC, Babyface, Babyface/Pro, MADIface XT / USB / Pro, Digiface USB - Legacy Build
Version 2.23. Compatible to 10.9 (OS X Mavericks) up to 10.13 (macOS High Sierra) Check OS Version. Legacy build, newer drivers are version 3.x. M1 user please download macOS 11 and up USB Series Driver.
2021-10-05
Mac OS X Intel driver for Fireface UFX, UCX, UC and Babyface
Version 1.68. Last driver to support 10.5.
2012-04-27
Windows
Download
2024-05-03
Download
fut_usb_win.zip
Windows 10
Download
Windows USB driver for Fireface UFX, 802, UCX, UCX II, UC and Babyface/Pro
Version 1.250, for Windows 8 and up.
2024-04-23
Windows 11
Download
2024-04-23
Windows 7
Download
2024-04-23
Windows 7 USB driver for Fireface UFX, 802, UCX, UCX II, UC and Babyface/Pro
Version 1.246, last driver for Windows 7.
2023-07-11
Windows 8
Download
2024-04-23
Windows XP SP2
Download
Last Windows XP SP2 PnP driver for Fireface Series and Babyface/Pro
Version1.093.
2016-07-22
Mac OS X
Download
TotalMix FX Mac latest version (single file download)
TotalMix FX V 1.93. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
2024-02-10
Download
tmfx_mac_193.zip
TotalMix Remote Mac
TotalMix Remote V 1.40 - App to remote control TotalMix FX via ethernet and WiFi from other devices with Mac OS 10.12 or up. Universal Binary, supports Intel and Mx. Please note: can not be run on the same computer where the host TotalMix FX is used. This download is not TotalMix FX, which is part of the driver installation.
2024-01-17
Windows
Download
TotalMix FX Windows latest version (single file download)
2024-02-10
Download
tmfx_win_193.zip
TotalMix Remote Windows
TotalMix Remote V 1.40 - Program to remote control TotalMix FX via ethernet and WiFi from other devices with Windows OS (PC, Tablet). Please note: can not be run on the same computer where the host TotalMix FX is used. This download is not TotalMix FX, which is part of the driver installation.
2024-01-17
Flash Update
Download
Mac OS Flash Update Tool for Fireface UFX/UCX/802
Update to firmware 344/27/7. Currently Fireface UFX/UCX/802 are updated via USB only. Please install the USB driver, then use the USB flash update which updates the FireWire firmware as well.
2016-01-26
Download
fut_usb_mac.zip
Windows Flash Update Tool for Fireface UFX/UCX/802
Update to firmware revision 344/27/7. Currently Fireface UFX/UCX/802 are updated via USB only. Please install the USB driver, then use the USB flash update which updates the FireWire firmware as well.
2016-01-26
Download
fut_usb_win.zip
Mac OS X
Download
macOS 11/12 FireWire Series Driver
Version 3.41, for macOS 11/12 only. Supports Intel and M1.
2021-11-10
Mac OS X FireWire driver for Fireface 400, 800, 802, UCX, UFX
Version 3.391. Compatible to OS 10.9 up to 10.15.
2021-09-22
2016-01-26
Download
fut_usb_mac.zip
Mac OS X Intel driver for Fireface 400, 800, UCX, UFX
Version 3.06. Supports 10.5 in 32 bit, 10.6 in 32/64 bit and 10.7. This driver requires firmware 1.70 (FF 400) and 2.77 (FF 800) or higher.
2012-01-19
Windows
Download
Windows 7 to 11 PnP FireWire driver for Fireface 400, 800, 802, UCX, UFX
Version 3.125.
2019-02-27
2016-01-26
Download
fut_usb_win.zip
Windows XP SP2
Download
Last Windows XP SP2 PnP driver Version 3.118.
2017-07-22
Zurück
Handbücher
Fireface UCX
Produkt
Beschreibung
Download PDF
Fireface UCX
Handbuch des Fireface UCX, Version 2.1, 07/2018
Produktbilder
Zurück
