Fireface UCX
36-Channel USB & FireWire Audio Interface
Fireface UCX
Products
Fireface UCX
The Fireface UCX is a highly integrated pro audio solution in an ultra-compact format for studio and live recordings. It continues RME's long tradition of designing compact high-end interfaces, packing into a half-rack size unit what usually would be spread out over two or three 19 inch panels.
“Recording the renowned drummer Kuniko”  - Drummer to Percussionist
Artists
The recording sessions are for Kuniko's 4th coming global release from LINN Records titled Works for Bach vol.1 (tbd.).
More info
How to “mix in a bus” with RME’s Fireface UFX
Artists
Soundesign Ltd. provides broadcast sound for radio, TV, film and music productions. To service this market they have built the Mixbus,...
More info
How to win the Latin Grammy Award with RME’s Fireface UCX
Artists
I am a recording and mixing engineer who has worked in Venezuela for more than 30 years. I studied at New York´s Institute of Audio Research ...
More info
Mr. Barrington's Hip Hop & Electronica sound makes the Fireface UCX a perfect fit
Artists
With an inspired blend of soaring melodies and daring musicianship, Mister Barrington's music has been described as a lovechild combo ...
More info
Purity Ring
Artists
Purity Ring
The ultra-low latency of RME interfaces and complex routing options of the Total Mix software are integral to our live setup.
More info
Connectivity and Features
8 x Analog I/O
2 x XLR/TRS Mic/Inst/Line
2 x Line/Inst Input
1 x Phones Output
1 x SPDIF I/O
1 x ADAT I/O
1 x Word Clock I/O
2 x MIDI I/O
FireWire or USB operation
Class Compliant Mode
TotalMix FX
ARC USB
RME USB 2.0
AutoSet Digital Gain Control
DC-coupled Outputs (Phones)
Including FX
High-End Converter with low latency Design
In doing this the Fireface UCX marks a new packing record: 300 electronic components more than inside the already well-stocked Fireface UC! In a tremendous effort RME packed once again all the latest technologies, introduced with the award winning flagship UFX, plus a bunch of newly developed ones, into a half 19 inch housing with full mobile usability.
The result is an awesome combination of RME's most successful products: Fireface UFX, Firefaces UC/400 and Babyface. The Fireface UCX is not just a smaller version of the smash hit UFX, with the HFX-core, the preamps and the complete effects engine. The UCX continues the tradition of RME's tremendously successful compact interfaces, and combines it with the Babyface's usability through the optional RME remotes.
TotalMix FX DSP Effects
TotalMix FX includes a complete effects system: EQ, Reverb, Dynamics & Delay
With the Fireface UCX RME reinvented an already perfect product, by improving existing features and characteristics plus adding sophisticated new ones:
  • Low Latency mastering grade converters with outstanding specifications.
  • Two mic preamps with the premium technology from RME's high-end recording bestsellers Micstasy and UFX, including the AutoSet overload protection.
  • A newly developed Hammerfall audio core, supporting USB and FireWire with the maximum performance and ultra-low latency operation, combined with the legendary RME driver stability and maintenance, on both bus protocols.
  • TotalMix FX with the complete Fireface UFX DSP engine, including all effects up to 192 kHz.
  • Monitoring Controller: combining the impressive flexibility of the TotalMix FX monitoring tool set and the optional RME Remote Control.
  • RME's unique DIGICheck metering and analysis toolbox for Windows PC and Mac.
    Plus support for RME's Advanced Remote Control, active jitter suppression technology, professional reference level support, advanced stand-alone functionality, full 192 kHz operation, and last but not least two high speed MIDI I/Os.
  • On top of it: The Fireface UCX is the first professional audio interface with Class Compliant mode to work with Apple's iPad, for perfect stereo up to 18 channel recording and playback, and the addition of truly professional I/Os.
So the UCX is a half rack unit, which is actually more powerful, than most 19 inch units. All in all the Fireface UCX is the new compact-sized dream interface, created with care for every detail, and a new premium solution for any desktop and live usage, without compromises in sound, stability and ultra-low latency operation.
TotalMix FX
Inputs and Outputs
The UCX provides 36 channels of audio - 18 I/Os. All channels can be used at the same time. Up to 8 analog and 10 digital channels can be recorded onto 18 separate tracks. All outputs can be used for ASIO Direct Monitoring purposes.
Available I/O (channels) with different Sample Rates:
Sample Rate Analog SPDIF ADAT Total In/Out
44.1/48 kHz 8/8 2/2 8/8 18/18
88.2/96 kHz 8/8 2/2 4/4 14/14
176.4/192 kHz 8/8 2/2 2/2 12/12
Analog I/O
The UCX provides 8 analog I/O in a very flexible combination:
8 Inputs
On the rear: 4 balanced TRS. On the front: 2 XLR inputs with Mic/Line preamps (65 dB Gain) and 2 Hi-Z capable TRS Line/Instrument inputs..
8 Outputs
On the rear: 6 balanced TRS outputs. On the front: One additional TRS stereo phones (playback channels 7/8). The high power phones output offers high volumes even with high-impedance headphones.
Sound Quality
Equipped with a new 2011 A/D and D/A high-performance converter design all I/Os operate at up to 192 kHz. The AD/DA conversion supersedes the outstanding technical specifications of the Fireface UC/400 with an impressive 114 dBA dynamic range on both record and playback. The advanced multi-bit converter architecture guarantees excellent S/N and THD specs across a wide analog level range. In the best RME tradition and product philosophy, the UCX converters and preamps have no characteristic "sound" of their own. They neither add nor remove anything, but capture the original signal just as it is.
Due to its efficient jitter reduction, RME's superior SteadyClockTM finalizes the state-of-the-art AD/DA conversion, even when clocking to an external digital source.
Low Latency Converters
All analog I/Os use a low latency converter design with impressive 14 samples for the ADC, and 7 samples for the DAC, independent of the used sample rate. These values are about a quarter of the Fireface UC/400 (43/28), and even outperform much more expensive devices. A technical breakthrough that reduces the overall latency of timing critical applications, in live situations, and in computer-based recording studios. The converter latency is so low (0.4 ms at 48 kHz) that it can be ignored, turning analog digital monitoring into real analog-style monitoring!
Professional Level Support
A great converter needs to support the common studio levels for the perfect adaptation to other analog equipment without loosing headroom. Like all other RME devices the UCX supports the common professional studio levels: -10 dBV, +4 dBu, Lo / HiGain. The software-controlled reference levels, realized discretely in the analog domain, ensure highest dynamic range and fidelity.
- Inputs 3 to 8: -10 dBV, +4 dBu and Lo Gain (adjustable in two groups - channels 3/4 and 5 to 8).
- Outputs 1 to 8: -10 dBV, +4 dBu and Hi Gain (adjustable in two groups - channels 1 to 6 and 7/8).
RME Audio Fireface UCX
36 channels of Audio into a half 19 inch housing with full mobile usability
Quality over quantity
The UCX provides two high-end mic and instrument preamps - built right into the front.
Like the famous UFX ones, both preamps use core technology of RME's Micstasy. A high-end preamp for supreme sonic demands and critical applications, like professional recordings of classical and acoustic music. The outstanding preamp design boasts extremely low distortion, excellent signal to noise ratio and a perfectly flat frequency response. A premium solution for transmitting and amplifying any audio source truly unchanged, be it high-level stage or typical studio signals, lower level and high-impedance instruments, or dynamic, condenser and ribbon microphones.
The digitally controlled gain of up to 65 dB, adjustable in steps of 1 dB over a range of 55 dB, is individually set for each preamp with the encoder knob on the front or in TotalMix FX on the host computer. All level settings are 100% reproducible and can also be adjusted using a MIDI remote controller.
Each channel can be individually switched to 48V phantom power. LEDs for signal, clip and activated phantom power give a complete overview on the unit's status.
The two TRS inputs on the front will alternatively operate as Hi-Z inputs. Directly plug in up to two guitars or other instruments - no other hardware is required.
AutoSet
The UCX offers a unique RME feature which was previously available only in the high-end microphone preamp Micstasy and the UFX. Usually a limiter is used during the recording to prevent clipping of the A/D converter stage. But analog processing would not only spoil the excellent technical specifications of the UCX mic preamps but also alter the original sound.
Thanks to digitally controlled gain the UCX can reduce the gain automatically, thus providing perfect protection from overload with no degradation of the audio signal, which does not have to pass any additional electronic circuitry. Additionally AutoSet does not cause any of the control noises known from usual limiters. SNR and THD stay completely unchanged.
Example: In a recording session, the recording engineer asks the vocalist or guitarist to sing or play a reference part and sets the UCX preamp gain to an unusual high level (e. g. 50 dB). AutoSet will automatically reduce the gain when the level reaches -6 dBFS. The reduction is done in a musical way, based on the intensity and duration of the input signal. Manual gain adjustment becomes obsolete most of the time, but the gain can still be set manually. AutoSet can be switched on for each of the 4 front panel mic and instrument preamp channels individually.
Digital I/O, Word Clock & MIDI
SPDIF: The UCX provides a coaxial SPDIF I/O working at up to 192 kHz.
ADAT: One 8-channel ADAT I/O expands the UCX by 8 channels available simultaneously with the analog channels. They can be used to connect an 8-channel AD/DA converter, a mixing console, or to insert an effect device. The ADAT I/O supports sample rates with up to 192 kHz (S/MUX4). Using an external converter like the ADI-8 QS, the UCX will provide 16 analog inputs and outputs, 12 with a sample rate of 96 kHz, and still 10 at 192 kHz.
SPDIF: The ADAT I/O can be used as optical SPDIF I/O, making the UCX connections even more flexible.
Word Clock & MIDI: A word clock input and output (BNC) with switchable termination plus two MIDI I/Os on a breakout cable complete the I/O list and turn the Fireface UCX into a professional audio system with universal usability.
TotalMix FX - Mixing/Routing with superior features for Studio and Live Work
Since 2001 TotalMix added unlimited routing and mixing to RME‘s audio interfaces. Its unique capability to create as many independent submixes as output channels available turned it into the most flexible and powerful mixer of its kind.
Find out More
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
The Fireface UCX is the first fully professional audio interface with the option to be used as Class Compliant interface.
The Class Compliant mode is a standard that is natively supported by operating systems like Windows, Mac OSX and Linux distributions. No proprietary drivers are required, the device will be directly recognized when the CC mode is activated by the button on the front panel.
The Class Compliant mode allows for connecting the UCX to any Apple iPadTM!
The iPad is not only an attractive mobile music creation and recording platform, but a closed hard- and software system without common driver problems and interferences from 3rd party hardware, like graphic or network cards. It provides stability, a good realtime performance and an easy handling.
The UCX provides the iPad with the professional analog I/O connections it lacks. Superb microphone preamps with EQ, dynamics, even with the AutoSet feature, in addition to professional balanced line outputs, and a hi-power headphone output that also excels with high impedance headphones. Plus level and gain adjustments, SPDIF/ADAT I/O, reverb, echo, zero latency monitoring, digitally via USB, without any limitation in quality, at up to 96 kHz and 24 bit.
The UCX adds another special feature: Instead of using the jitter-prone USB clock, it works with its own internal SteadyClock. Many USB audio devices extract clock for DA conversion from the USB data packets, running in slave mode (adaptive mode), with comparably high jitter values, especially since most won't offer active jitter suppression. The UCX works in clock mode master (asynchronous mode), both during recording and playback, thus achieving the exact same sound quality with an iPad as under Windows and Mac OSX.
Supported Inputs and Outputs . When connected to an iPad, the analog mic/line input 1 works with mono apps, inputs 1 and 2 with stereo apps (both dual mono and stereo), and up to 8 inputs with 8-channel applications, like MultiTrack DAW and Music Studio. Garage Band supports all inputs, but only two at a time. Auria can record all 18 inputs simultaneously.
Playback will use analog outputs 1 and 2, or even more channels if the app supports such operation. The UCX can optionally copy the iPad playback channels 1/2 to outputs 7/8 and SPDIF/ADAT, for easier monitoring. All outputs can be processed independently (volume, EQ, dynamics, FX return).
Audio Routing and Processing
The UCX is also a very powerful tool in CC mode, and can even be pre-configured via TotalMix FX under Windows/Mac. Apart from the current configuration up to 6 previously saved configurations can be loaded from the setup memory, allowing for a quick reconfiguration without a connected host PC/Mac.
The input signal will pass through all activated functions of the TotalMix FX input channel, namely settings, EQ, and Dynamics, and is then sent to the iPad. Like under Windows and Mac, the input fader controls direct monitoring to any output. The FX send control for echo/reverb is also active. The iPad's output signal passes through all activated functions of the TotalMix FX hardware outputs, namely settings, EQ, and dynamics. The third row's fader sets the output level.
SteadyClock
RME's unique jitter suppression technology guarantees perfect sound quality throughout, making the device completely independent from the quality of external clock signals. Due to the highly efficient jitter reduction, the UCX converters operate independently from the quality of the external clock signal, as if they are working with internal clock all the time - guaranteeing a pristine sound quality!
SteadyClock allows the Fireface UCX to control the sample rate freely on its own. The settings dialog includes a direct choice of the video and audio world's most often used sample rates.
ICC[nbsp]Intelligent Clock Control
Intelligent Clock Control not only displays every clock status, but will also retain the last valid input sample rate in case of failure of the external source. Other renowned RME technologies like SyncCheck offer a quick detection of clock problems.
DIGICheck
The UCX comes with RME's unique software tool box for metering, testing, measuring and analyzing digital audio streams. It provides a multi-track recorder, calculates the level meters peak and RMS in hardware and is able to analyze and display playback data from any software, no matter which format the software uses.*
Stand Alone Operation with Setup Recall
Additionally internal memory allows for the permanent storage of six different states of the unit. Therefore the Fireface UCX is able to operate fully stand-alone, without any connected computer. In stand-alone operation it can transform into totally different devices by the simple click of a button. Furthermore, in this mode TotalMix FX can also be controlled via MIDI. Application examples include: 8-channel AD/DA converter, 4-channel mic preamp, monitor mixer, digital format converter, analog/digital routing matrix.
Accessories
19" Rackmounts
Specs
Fireface UCX
AD, Line In 5-8, rear
  • Signal to Noise ratio (SNR): 111 dB RMS unweighted, 113 dBA
  • Frequency response @ 44.1 kHz, -0.5 dB: 6 Hz - 20.6 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 6 Hz - 45.3 kHz
  • Frequency response @ 192 kHz, -1 dB: -1 dB: 5 Hz - 90 kHz
  • THD: < -105 dB, < 0.0005 %
  • THD+N: < -98 dB, < 0.0012%
  • Maximum input level: +19 dBu
  • Channel separation: > 110 dB
  • Input: 6.3 mm TRS jack, electronically balanced
  • Input sensitivity switchable to Lo Gain, +4 dBu, -10 dBV
  • Input level for 0 dBFS @ Lo Gain: +19 dBu
  • Input level for 0 dBFS @ +4 dBu: +13 dBu
  • Input level for 0 dBFS @ -10 dBV: +2 dBV
DA, Line Out 1-6, rear
  • Dynamic range (DR): 111 dB, 113 dBA @ 44.1 kHz (unmuted)
  • Frequency response @ 44.1 kHz, -0.1 dB: 8 Hz - 20.4 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 6 Hz - 45 kHz
  • Frequency response @ 192 kHz, -1 dB: 6 Hz - 90 kHz
  • THD: -100 dB, < 0.001 %
  • THD+N: -96 dB, < 0.0015 %
  • Maximum output level: +19 dBu
  • Output: 6.3 mm TRS jack, servo-balanced
  • Output impedance: 75 Ohm
  • Output level switchable: Hi Gain, +4 dBu, -10 dBV
  • Output level at 0 dBFS @ Hi Gain: +19 dBu
  • Output level at 0 dBFS @ +4 dBu: +13 dBu
  • Output level at 0 dBFS @ -10 dBV: +2 dBV
Line In 3-4, front
As AD, but:
  • Additional Gain stage: 0 up to +12 dB
  • Maximum input level, Lo Gain, Gain 0 dB:
  • Line +19 dBu, Inst +13 dBu
  • Maximum input level, -10 dBV, Gain 12 dB, Line:
  • -7,5 dBu, Inst: -13,5 dBu
  • Input impedance Inst: 470 kOhm
  • Input Gain Inst: +6 dB
  • Input mode: Line balanced (TRS), Inst unbalanced (TS)
  • CLIP LED: 0 dBFS
  • SIG LED: -60 dBFS
DA - Phones, 7/8, front
As DA, but:
  • Output: 6.3 mm TRS jack, unbalanced
  • Output impedance: 30 Ohm
  • Word Clock
  • BNC, switch for internal termination 75 Ohm
Microphone/Line 1-2, front
as AD Line In 5-8, but:
  • Input: Neutrik XLR/TRS Combo jack, electronically balanced
  • Input impedance: XLR 2 kOhm, TRS 8 kOhm balanced
  • Signal to Noise ratio (SNR): 112 dB RMS unweighted, 115 dBA
  • Low Roll Off -0.5 dB: 18 Hz, -1 dB: 12 Hz
  • Gain range: 0 dB, +10 up to +65 dB
  • Maximum input level XLR, Gain 0 dB: +10 dBu
  • Maximum input level XLR, Gain 65 dB: -55 dBu
  • Maximum input level TRS, Gain +0 dB: +21 dBu
  • Maximum input level TRS, Gain +65 dB: -44 dBu
  • CLIP LED: 0 dBFS
  • SIG LED: -60 dBFS
All specifications are subject to change without notice.
Back
Drivers
Fireface UCX
Flash Update
Release date
Download
Mac OS Flash Update Tool for Fireface UFX, 802, UCX, UCX II, UC, Babyface/Pro
Update to version UFX: 361/163/344/29, 802 A: 20/9/9/12, 802 E: 112/101/101/9, 802 FS: 227/ 215/ 31, UCX: 49/260/27/14, UCX II (6): 43/36/21, UCX II (7): 106/36/104, UC: 127/138, Babyface: 226, Babyface Pro & FS: 211/322.
Release date
2025-09-01
Download
fut_usb_mac.zip
Windows Flash Update Tool for Fireface UFX, 802, UCX, UCX II, UC, Babyface Pro
Update to firmware revision UFX: 361/163/344/29, 802: 20/9/9/12 (A), 112/9/101/101 (E), 802 FS: 227/31/215, UCX: 49/260/27/14, UCX II (6): 43/36/21, UCX II (7): 106/36/104, UC: 127/138, Babyface: 226, Babyface Pro & FS: 211/322.
Release date
2025-09-01
Download
fut_usb_win.zip
Mac OS X
Release date
Download
macOS 11 or up USB Series DriverKit Driver+Fut
macOS 11 or up USB series DriverKit driver, v. 4.31.
Release date
2026-10-24
macOS 11 and up USB Series Kernel Extension Driver
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.39. Supports Intel and Mx.
Please read carefully how to install Intel & M1 & up Driver for RME Audio Interfaces
Release date
2026-06-06
macOS 10.12 up to 10.15 driver for Fireface UFX / UFX+ / UFX III, UFX II, 802, UCX, UCX II, UC, Babyface, Babyface Pro, MADIface XT/USB/Pro, Digiface USB/AES/Dante/Ravenna
Version 3.224. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. M users please download macOS 11 and up USB Series Driver.
Release date
2026-06-05
Mac OS X driver for Fireface UFX / UFX+ / UFX II, 802, UCX, UCX II, UC, Babyface, Babyface/Pro, MADIface XT / USB / Pro, Digiface USB - Legacy Build
Version 2.24. Compatible to 10.9 (OS X Mavericks) up to 10.13 (macOS High Sierra) Check OS Version. Legacy build, newer drivers are version 3.x. M user please download macOS 11 and up USB Series Driver.
Release date
2026-02-18
Release date
2025-09-01
Download
fut_usb_mac.zip
Mac OS X Intel driver for Fireface UFX, UCX, UC and Babyface
Version 1.68. Last driver to support 10.5.
Release date
2012-04-27
Windows
Release date
Download
Release date
2025-09-01
Download
fut_usb_win.zip
Windows 10
Release date
Download
x64 / Arm 64 bit driver for Windows 10 and up, Fireface USB series
Driver for Windows 10 / 11, Intel x64 and Arm, version 1.277. Supports Intel Windows 10 or up 64 bit and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Release date
2026-09-21
Windows USB driver for Fireface UFX, 802, UCX, UCX II, UC and Babyface/Pro
Version 1.253, for Windows 8 and up. Last version to support Windows 32 bit.
Release date
2024-10-17
Windows 11
Release date
Download
Release date
2026-09-21
Release date
2024-10-17
Windows 7
Release date
Download
Release date
2024-10-17
Windows 7 USB driver for Fireface UFX, 802, UCX, UCX II, UC and Babyface/Pro
Version 1.246, last driver for Windows 7.
Release date
2023-07-11
Windows 8
Release date
Download
Release date
2024-10-17
Windows XP SP2
Release date
Download
Last Windows XP SP2 PnP driver for Fireface Series and Babyface/Pro
Version1.093.
Release date
2016-07-22
Mac OS X
Release date
Download
TotalMix FX 2.x Mac, Installer, latest version
TotalMix FX V 2.10 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Mac, v 1.99 (single file download)
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Download
tmfx_mac_199.zip
TotalMix Remote Mac
Release date
2024-10-17
Windows
Release date
Download
TotalMix FX Windows 32 bit, v1.99 (single file download)
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
TotalMix Remote Windows
Release date
2024-10-17
Windows 10
Release date
Download
TotalMix FX 2.x Windows Installer, latest version
TotalMix FX V 2.10 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Windows 64 bit, v199 (single file download)
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
Release date
2025-05-05
Windows 11
Release date
Download
Release date
2026-10-22
TotalMix FX Arm64 v 1.99 (single file download)
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Release date
2025-05-05
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and Mx machines. DigiCheck NG V 0.93 requires macOS 10.13 (High Sierra) or up.
Release date
2025-05-26
DIGICheck 0.73 Mac
Release date
2017-09-14
Download
dc_073_mac.zip
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Windows 10
Release date
Download
DigiCheck NG Windows
Release date
2025-05-26
Windows 11
Release date
Download
Release date
2025-05-26
Windows Vista
Release date
Download
DIGICheck 4.53 (Works with all RME cards, except HDSPe RayDAT and AIO)
Stereo Level Meter, Multichannel Level Meter, Global Level Meter, Spectral Analyser, Vector Audio Scope, Correlation Meter, Totalyser, Bit Statistic & Noise, Global Record. ASIO support, multi-client operation, display of +dBFS levels, display of playback data, K-system, free reference/scale, third colour. New: Hardware Level Meter. RMS Slow and RLB weighting filter. Optional Correlator. Level meters vertical/horizontal. Presets with hotkeys. Support for Fireface 400, newer Fireface 800 drivers, HDSP series WDM driver. Record functionality Global Record. Compatible to HDSPe PCI and HDSPe MADI/MADIface
Release date
2008-09-02
Download
dc_453.zip
Windows XP SP2
Release date
Download
Release date
2008-09-02
Download
dc_453.zip
Flash Update
Release date
Download
Mac OS Flash Update Tool for Fireface UFX/UCX/802
Update to firmware[nbsp]344/27/7. Currently Fireface UFX/UCX/802 are updated via USB[nbsp]only. Please install the USB driver, then use the USB flash update which updates the FireWire firmware as well.
Release date
2016-01-26
Download
fut_usb_mac.zip
Windows Flash Update Tool for Fireface UFX/UCX/802
Update to firmware revision 344/27/7. Currently Fireface UFX/UCX/802 are updated via USB only. Please install the USB driver, then use the USB flash update which updates the FireWire firmware as well.
Release date
2016-01-26
Download
fut_usb_win.zip
Mac OS X
Release date
Download
macOS 11 or up FireWire Series Driver
Version 3.41, for macOS 11 or up. Supports Intel and Mx (Apple Silicon).
Release date
2021-11-10
Mac OS X FireWire driver for Fireface 400, 800, 802, UCX, UFX
Version 3.391. Compatible to OS 10.9 up to 10.15.
Release date
2021-09-22
Release date
2016-01-26
Download
fut_usb_mac.zip
Mac OS X Intel driver for Fireface 400, 800, UCX, UFX
Version 3.06. Supports 10.5 in 32 bit, 10.6 in 32/64 bit and 10.7. This driver requires firmware 1.70 (FF 400) and 2.77 (FF 800) or higher.
Release date
2012-01-19
Windows
Release date
Download
Windows 7 to 11 PnP FireWire driver for Fireface 400, 800, 802, UCX, UFX
Version 3.125.
Release date
2019-02-27
Release date
2016-01-26
Download
fut_usb_win.zip
Windows XP SP2
Release date
Download
Last Windows XP SP2 PnP driver Version 3.118.
Release date
2017-07-22
Back
Manuals
Fireface UCX
Product
Description
Download PDF
Fireface UCX
Latest manual for Fireface UCX, version 2.1, 07/2018
Product Images
Back
No longer available and replaced by the new Fireface UCX II
