M-1620 Pro
16 channel A/D, 20 channel D/A converter with ADAT, Milan®, MADI
M-1620 Pro
Products
M-1620 Pro
16 channel A/D, 20 channel D/A converter with ADAT, Milan®, MADI and separate phones out
The RME M-1620 Pro converts 16 analog line-level signals (per channel switchable up to +24 dBu) to and from MADI, ADAT and Milan network technology. This innovative unit is designed with a newly developed front panel that combines LED level meters with a display and includes two separate headphone outputs for monitoring - all within a single-height 19-inch rack device. Cutting-edge converters and flexible internal routing place it at the forefront of any audio network.
Floor 4 Studio by Timo Klemm
Artists
Insights into the structure and operation of a modern studio that specializes in Atmos productions with excellent technology, infrastructure and acoustics.
More info
Connectivity and Features
16 x Line Input
16 x Line Output
2 x Phones Output
4 x ADAT I/O
1 x MADI Optical SFP (optional)
1 x Redundant PSU (optional)
1 x Word Clock I/O
1 x MADI I/O coaxial
2 x Gigabit Ethernet (802.3 compliant)
SteadyClock FS
DC-coupled Outputs
USB for firmware & remote control
Simplicity at first glance - Flexibility and reliability beyond
RME prioritizes reliability by equipping the M-1620 Pro with built-in redundancy. This includes dual network and dual MADI connections, along with a monitored DC input in addition to the internal AC power supply. A unique system clearly signals when an issue arises, ensuring seamless operation. With full stand-alone capability, users can adjust device settings directly on the unit for quick modifications or to recall entire user-defined presets.
The Milan-certified model transmits and receives up to 128 channels at 48 kHz (96 @ 96 kHz, 64 @ 192 kHz) with precise, fixed latency across a deterministic network. It reveals its status and configurable options to controllers using the open IEEE 1722.1 (ATDECC) standard.
Multiple layers of redundancy make the M-1620 Pro Series a perfect companion for any kind of live sound application.
Add Analog and AVB I/O to any existing MADI devices
The M-1620 Pro allows manual configuration of the converter’s aliasing filters for optimal impulse and frequency response. Jitter on digital input signals is effectively reduced with SteadyClock FS. Separate Word Clock BNC and coaxial MADI connectors, with optional optical MADI via an SFP module, allow the device to be easily integrated into existing infrastructure.
Perfect for recording engineers using a variety of analog effects and instruments.
Plug & play - rapid user interaction
Control all device states directly from the front panel for convenient, direct access to all features. RME AVB devices can also be fully remote controlled via a web-interface on any network link (including wirelessly over Wi-Fi), allowing for the rapid creation of gain groups, phantom power switching, and routing of signals to headphones for monitoring. The integrated routing matrix allows for quick routing of any analog inputs straight to the headphone output, as well as all digital signals and AVB streams. As such, problem-solving of signals, clocking, connectivity or other issues is both simple and straight-forward!
Direct access to all features via the web-interface on any network
More Outstanding Features
Accessories
Optical MADI SFP Module (optional available)
This module extends compatible RME devices with an optical SFP transceiver. Up to 64 audio channels can then be sent to and received from other MADI devices. THE RME SFP module is available in a Multi-Mode and in a Single-Mode version, it can be inserted and removed while the RME MADI device is powered on. It is not necessary to power down the device.
More Info
Specs
M-1620 Pro
Line In 1-16:
  • Resolution: 24 bit
  • Input level switchable per channel +24 dBu, +19 dBu, +13 dBu @ 0 dBFS
  • Inputs AC coupled, fully symmetrical signal path (servo-balanced)
  • Input Impedance 9.5 kΩ
  • Signal to Noise ratio (SNR) @ +24 dBu, 44.1 kHz: 117.0 dB RMS unweighted, 120.7 dBA
  • Signal to Noise ratio (SNR) @ +19 dBu: 116.3 dB RMS unweighted, 119.9 dBA
  • Signal to Noise ratio (SNR) @ +13 dBu: 114.7 dB RMS unweighted, 118.3 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 5 Hz – 20.5 kHz
  • THD @ -1 dBFS: < -111 dB, < 0.00029%
  • THD+N @ -1 dBFS: < -108 dB, < 0.00039 %
  • Channel separation: > 110 dB
Line Out 1-16:
  • Output level switchable per channel +24 dBu, +19 dBu, +13 dBu @ 0 dBFS
  • Outputs DC coupled, fully symmetrical signal path ("truly balanced")
  • Output impedance: 200 Ohm balanced, 100 Ohm unbalanced
  • Signal to Noise Ratio (SNR) @ 13 dBu: 119.2 dB RMS unweighted
  • Signal to Noise Ratio (SNR) @ 19 dBu: 119.7 dB RMS unweighted
  • Signal to Noise Ratio (SNR) @ 24 dBu: 119.9 dB RMS unweighted
  • Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.3 kHz (Sharp Filter, default)
  • Frequency response @ 96 kHz, -0.1 dB: 0 Hz – 30 kHz (Slow Filter, default)
  • Frequency response @ 96 kHz, -0.1 dB: 0 Hz – 44.1 kHz (Sharp Filter)
  • Frequency response @ 192 kHz, -0.1 dB: 0 Hz – 60.5 kHz (Slow Filter, default)
  • Frequency response @ 192 kHz, -0.1 dB: 0 Hz – 85 kHz (Sharp Filter)
  • THD @ 19 dBu: < -120 dB, < 0.0001 %
  • THD+N @ 19 dBu: < -113 dB, < 0.0002 %
Phones 1/2, 3/4:
  • Resolution: 24 Bit
  • Output: 6.3 mm TRS stereo (unbalanced) or mono (balanced) jack
  • Maximum output level +4 dBu / +19 dBu (+10 dBu / +25 dBu in balanced mode)
  • Output level switchable separately for each TRS connector
  • Signal to Noise Ratio (SNR) @ 19 dBu: > 109 dB RMS unweighted, > 111 dB(A)
  • Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.0 kHz (Sharp Filter, default)
  • Frequency response @ 96 kHz, -0.1 dB: 0 Hz – 20.0 kHz (Slow Filter, default)
  • Frequency response @ 96 kHz, -0.1 dB: 0 Hz – 44.3 kHz (Sharp Filter)
  • Frequency response @ 192 kHz, -0.1 dB: 0 Hz – 43 kHz (Slow Filter, default)
  • THD+N @ 4 dBu, 32 Ohms load: < -100 dB, < 0.001 %
  • THD+N @ 19 dBu, 100 Ohms load: < -100 dB, < 0.001 %
Back
Drivers
M-1620 Pro
Flash Update
Release date
Download
M-1620 Pro Firmware Update
Firmware 3.0.7. Main update. Adds MILAN certification. Carefully read the instructions in the readme.pdf!
Release date
2025-04-02
Back
Manuals
M-1620 Pro
Product
Description
Download PDF
M-1620 Pro
Latest M-1620 Pro manual
Product Images
Back
