Fireface UFX II
60-Channel 192kHz high-end USB Audio Interface now with SteadyClock FS
Fireface UFX II
Products
Fireface UFX II
RME USB Premium Flagship Interface
The unique Fireface UFX II is the premier solution to transfer analog and digital audio data directly to a computer from practically any source.
Numerous unique features like SteadyClock FS, improved AD/DA Conversion, DC-coupled analog outputs, well thought-out configuration dialogs, an industry-leading mixing engine and monitoring solution, professional DSP effects and class-leading analog circuits with latest digital converters put the Fireface UFX II at the very top of the range of computer-based audio interfaces.
Andres Forero - The Busiest Drummer on Broadway
Artists
Grammy, Emmy, and Tony award-winning Andres Forero’s credits include drummer for Broadway hits (Hamilton; Book of Mormon), television and performances.
More info
Recording shows for a Live album
Artists
Howard Heckers, FOH-Sound-engineer, Producer and Studio engineer. Working for almost 10 years for Roger Hodgson co-founder of Supertramp, touring worldwide for audiences keen to hear his music.
More info
Singer-songwriter, composer and producer BC Bogey
Artists
BC Bogey aka VOICE IN THE ATTIC has gained international recognition for his works, winning several awards.
More info
Wim Daans - Night of the Proms Tour
Artists
Wim Daans is one of the new breed of multifaceted technicians, blurring the lines between artistry, production and technology in a diversity of disciplines.
More info
Connectivity and Features
12 x Analog I/O
4 x XLR/TRS Mic/Inst/Line
2 x Phones Output
1 x AES/EBU I/O
2 x ADAT I/O
1 x Word Clock I/O
2 x MIDI I/O
1 x RME USB 2.0
TotalMix FX
ARC USB
DURec
Class Compliant Mode
AutoSet Digital Gain Control
DC-coupled Outputs
Including FX
SteadyClock FS
The first choice of Audio Professionals around the World
With exceptional flexibility and compatibility, the inclusion of DURec (Direct USB Recording), and RME’s famous low latency hardware and driver designs, the Fireface UFX II delivers a rich feature set that will appeal to users in both high end home studios and commercial audio production facilities.
With capacity for 60 audio channels (30 input and 30 output), support for sampling frequencies upward of 192 kHz, and the flexibility provided by USB connectivity, the new Fireface UFX II is an ideal solution to a wide range of recording, mixing, and monitoring applications.
The Fireface UFX II offers excellent flexibility that enables the interface to fit seamlessly into a myriad of production environments. Analog, ADAT, AES, SPDIF, and USB 2 are all standard on the Fireface UFX II. Equally impressive is the unit’s channel count: 12 analog, 16 ADAT, and 2 AES for 30 channels input and 30 channels output. Further, with support for USB 2 connectivity, the new Fireface UFX II can integrate with RME’s optional ARC USB remote controller.
RME’s Fireface UFX II incorporates premium AD/DA converters, optimized analog I/O circuits, as well as improved SNR and THD values to guarantee pristine, crystal clear and transparent audio. A new PAD-free mic circuit design with +18 dBu maximum input level and 75 dB gain range provides trouble-free operation for the most demanding recording environments.
Further, new low impedance, high power phones outputs (2 Ohms) with +19 dBu maximum output level provide ample output power and volume on any headphones - high or low impedance.
TotalMix-FX
Flexible Routing & Mixing with TotalMix FX
Since 2001, TotalMix has added unlimited routing and mixing to RME audio interfaces. Its unique capability to create as many independent submixes as output channels available, turned it into the most flexible and powerful mixer of its kind.
With supported hardware, TotalMix FX includes a complete effects system, which not only adds flexibility to the recording chain, but also makes latency saddled software solutions obsolete.
TotalMix FX can completely replace an external mixer, enabling the creation of multiple latency-free monitor mixes with EQ, Dynamics, Reverb and Delay for any outputs, incl. main monitors and headphone mixes for musicians.
TotalMix FX DSP Effects
TotalMix FX includes a complete effects system: EQ, Reverb, Dynamics & Delay
DC-Coupled Outputs - CV/Gate Voltage Control
Most audio interfaces are traditionally designed with what is called 'AC-coupled outputs', where capacitors are used to filter out any extreme low frequencies.
Whilst these frequencies are generally considered undesirable for audio - eating into headroom and potentially causing damage to other equipment - one instance where DC-coupling remains desirable is the world of modular synthesizers, where static or slow-moving signals are used for control over various parameters such as pitch note values or LFOs.
All of the Fireface UFX II’s line-level outputs are fully DC-coupled, allowing for the sending of control voltages (CV) or Gate information to modular synthesizers (such as the popular Eurorack and Moog/MOTM/Synthesizers formats) and other studio hardware.
TotalMix FX for iPad™ App
TotalMix FX for iPad™ adds full control over hardware mixer and DSP effects for Fireface UFX+, UFX II, UCX, 802, Babyface, Babyface Pro and MADIface Pro when in Class Compliant Mode, and lets you create, store and load complete mixes directly from the iPad™
More Outstanding Features
TotalMix FX - Mixing/Routing with superior features for Studio and Live Work
Since 2001 TotalMix added unlimited routing and mixing to RME‘s audio interfaces. Its unique capability to create as many independent submixes as output channels available turned it into the most flexible and powerful mixer of its kind.
Find out More
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
SteadyClock FS - Reference class Digital Clocking
Excellent performance in all clock modes and High Quality Analog Conversion to hear your mix as it is, with lowest jitter and highest jitter immunity.
Find out more
Room EQ in TotalMix FX
The latest Room EQ addition provides an optimized handling of the existing 3-band PEQ in TotalMix FX, including 9-band PEQ, Volume Calibration and Crossfeed function.
Find out More
ARC USB
[nbsp]
ARC USB Remote Control - Plug’n Play Plus
The ARC USB connects to your computer via USB, and talks to TotalMix FX directly. It has 15 freely assignable and illuminated buttons, one encoder wheel, and a TS jack to connect a foot switch.
The ARC USB is a USB 1.1 MIDI remote control for the Fireface UFX II. Thanks to operating as a UAC 1 class device, it is natively compatible to Windows and Mac OS X. As soon as it is present in the operating system, TotaIMix FX will automatically detect the ARC USB, and communicate with it via simple MIDI remote commands to control the UFX II.
Direct to Disc USB recording
All 60 input and output channels can be individually chosen for recording and playback
[nbsp]
DURec is an integrated digital recorder for all inputs and outputs directly to USB memory devices via the front USB port. The Fireface UFX III and Fireface UFX II records on USB thumb drives or hard drives with up to 2 TB capacity. The recording functionality is provided by the internal DSP, and is therefore independent from a connected Windows or Mac computer. The Direct USB Recording converts the Fireface UFX Series both into a stand-alone field recorder and a powerful multichannel live player for previous recordings, e. g. for virtual sound checks. Live concerts, band rehearsals or spontaneous jam sessions can be directly recorded and played back from the medium - even completely stand-alone without computer or software.
[nbsp]
Specs
Fireface UFX II
Analog
AD, Line In 1-8, rear
  • Input: 6.3 mm TRS, electronically balanced
  • Signal to Noise ratio (SNR) @ LoGain: 116 dB (AES17), 118 dBA
  • Signal to Noise ratio (SNR) @ +4 dBu: 115 dB (AES17), 117 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 8.9 Hz – 20.4 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 4.3 Hz – 45.2 kHz
  • Frequency response @ 192 kHz, -1 dB: 3 Hz – 89 kHz
  • Filter: Short Delay Sharp, 5 / 5 / 6 samples delay
  • THD @ -1 dBFS: < -120 dB, < 0.0001 %
  • THD+N @ -1 dBFS: < -110 dB, < 0.00032 %
  • Channel separation: > 110 dB
  • Maximum input level: +19 dBu
  • Input: 6.3 mm TRS jack, electronically balanced
  • Input impedance @ 1 kHz: 10 kOhm unbalanced, 10.6 kOhm balanced
  • Input sensitivity switchable between Lo Gain and +4 dBu
  • Input level for 0 dBFS @ Lo Gain: +19 dBu
  • Input level for 0 dBFS @ +4 dBu: +13 dBu
  • Variable digital gain: 0 to +12 dB
  • Minimum level for 0 dBFS: +1 dBu, -1.2 dBV
Microphone In 9-12, front
As AD, but:
  • Input: XLR, electronically balanced
  • Input impedance @ 1 kHz: 3.4 kOhm
  • Signal to Noise ratio (SNR) @ 0 dB Gain: 117 dB (AES17), 119.5 dBA
  • THD+N @ -1 dBFS, Gain 20 dB: < -110 dB, < 0.00032 %
  • Frequency response @ 44.1 kHz, -0.1 dB: 10.7 Hz – 20.3 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 5.1 Hz – 45.0 kHz
  • Frequency response @ 192 kHz, -1 dB: 3.5 Hz – 88 kHz
  • EIN @ 60 dB Gain, 150 Ohm, A-Weighted: -129.8 dBu
  • Gain range: 75 dB
  • Maximum input level, Gain 0 dB: +18 dBu
  • Maximum input level, Gain 75 dB: -57 dBu
  • CLIP LED: 0 dBFS
  • SIG LED: -60 dBFS
Instrument In 9-12, front
As AD, but:
  • Output: 6.3 mm TRS jack, servo-balanced
  • Signal to Noise ratio (SNR) @ HiGain: 116.5 dB (AES17), 118.5 dBA
  • Signal to Noise ratio (SNR) @ +4 dBu: 116 dB (AES17), 118 dBA
  • Signal to Noise ratio (SNR) @ -10 dBV: 107 dB (AES17), 109 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.2 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 44.6 kHz
  • Frequency response @ 192 kHz, -1 dB: 0 Hz – 77.5 kHz
  • THD+N: < -110 dB, < 0.00032 %
  • Output level switchable Hi Gain, +4 dBu, -10 dBV
  • Output level at 0 dBFS @ Hi Gain: +19 dBu
  • Output level at 0 dBFS @ +4 dBu: +13 dBu
  • Output level at 0 dBFS @ -10 dBV: +2 dBV (+4.2 dBu)
  • Output impedance: 75 Ohm
DA, Line Out 3-8, rear
  • Resolution: 24 bit
  • Dynamic range (DR): 115 dB RMS unweighted, 118 dBA
  • Frequency response @ 44.1 kHz, -0.5 dB: 5 Hz – 20.8 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 5 Hz – 45 kHz
  • Frequency response @ 192 kHz, -1 dB: 5 Hz - 89 kHz
  • THD: < -110 dB, < 0.00032 %
  • THD+N: < -104 dB, < 0.00063 %
  • Maximum output level: +19 dBu
  • Output impedance: 75 Ohm unbalanced, 150 Ohm balanced
DA - Stereo Monitor Output XLR (1-2)
As DA, but:
  • Output: XLR, balanced
  • Output level switchable 24 dBu, Hi Gain, +4 dBu, -10 dBV
  • Output level at 0 dBFS @ 24 dBu: +24 dBu
  • Output impedance: 150 Ohm
DA - Stereo Monitor Output Phones (9-12)
As DA, but:
  • Output: 2 x 6.3 mm TRS stereo jack, unbalanced
  • Maximum output level at 0 dBFS, High: +19 dBu
  • Maximum output level at 0 dBFS, Low: +2 dBV
  • Max power per channel @ 32 Ohm load, 0.02% THD: 200 mW (2.5 Vrms, +10 dBu)
  • Signal to Noise ratio (SNR) @ High: 116.5 dB (AES17), 118.5 dBA
  • Signal to Noise ratio (SNR) @ Low: 115 dB (AES17), 117 dBA
  • Output impedance: 2 Ohm
MIDI
  • 2 x MIDI I/O via 5-pin DIN jacks
  • Galvanically isolated by optocoupled input
  • Hi-speed mode: Jitter and response time typically below 1 ms
  • Separate 128 byte FIFOs for input and output
Digital
  • Clocks: Internal, ADAT, AES, MADI, word clock
  • Low Jitter Design: < 1 ns in PLL mode, all inputs
  • Internal clock: 800 ps Jitter, Random Spread Spectrum
  • Jitter suppression: > 50 dB (> 1 Hz)
  • Effective clock jitter influence on AD and DA conversion: near zero
  • PLL ensures zero dropout, even at more than 100 ns jitter
  • Digital Bitclock PLL for trouble-free varispeed ADAT operation
  • Supported sample rates: 28 kHz up to 200 kHz
Digital Inputs
AES/EBU
  • 1 x XLR, transformer-balanced, galvanically isolated, according to AES3-1992
  • High-sensitivity input stage (< 0.3 Vpp)
  • SPDIF compatible (IEC 60958)
  • Accepts Consumer and Professional format
  • Lock range: 27 kHz – 200 kHz
  • Jitter when synced to input signal: < 1 ns
ADAT Optical
  • 2 x TOSLINK, format according to Alesis specification
  • Standard: 2 x 8 channels 24 bit, up to 48 kHz
  • Double Speed (S/MUX): 2 x 4 channels 24 bit 96 kHz
  • Quad Speed (S/MUX4): 2 x 2 channels 24 bit 192 kHz
  • Bitclock PLL ensures perfect synchronisation even in varispeed operation
  • Lock range: 31.5 kHz – 50 kHz
SPDIF optical (ADAT2)
  • 1 x optical, according to IEC 60958
Word Clock
  • BNC
  • Internal termination 75 Ohm switchable
  • Automatic Double/Quad Speed detection and internal conversion to Single Speed
  • SteadyClock guarantees super low jitter synchronization even in varispeed operation
  • Not affected by DC-offsets within the network
  • Signal Adaptation Circuit: signal refresh through auto-center and hysteresis
  • Overvoltage protection
  • Level range: 1.0 Vpp – 5.6 Vpp
  • Lock Range: 27 kHz – 200 kHz
Digital Outputs
AES/EBU
  • XLR, transformer-balanced, galvanically isolated, according to AES3-1992
  • Output level Professional 4.5 Vpp, Consumer 2.6 Vpp
  • Format Professional according to AES3-1992 Amendment 4
  • Format Consumer (SPDIF) according to IEC 60958
  • Single Wire mode, sample rate 28 kHz up to 200 kHz
ADAT
  • 2 x TOSLINK
  • Sample rate 28 kHz up to 200 kHz
Word Clock
  • BNC
  • Max. output voltage: 5 Vpp
  • Output voltage @ 75 Ohm termination: 4.0 Vpp
  • Output impedance: 10 Ohm
  • Frequency range: 27 kHz – 200 kHz
General
  • Power supply: Internal switching PSU, 100 - 240 V AC, 36 Watts
  • Idle power consumption: 19 Watts
  • Typical power consumption: 22-25 Watts
  • Dimensions including rack ears (WxHxD): 483 x 44 x 210 mm (19" x 1.73" x 8.5")
  • Dimensions without rack ears (WxHxD): 440 x 44 x 210 mm (17.3" x 1.73" x 8.3")
  • Total depth: 240 mm (9.4”)
  • Weight: 3 kg ( 6.6 lbs)
  • Temperature range: +5° up to +50° Celsius (41° F up to 122°F)
  • Relative humidity: < 75%, non condensing
All specifications are subject to change without notice.
Back
Drivers
Fireface UFX II
Flash Update
Release date
Download
Mac OS Flash Update Tool for MADIface XT/XT II/USB/Pro, OctaMic XTC, ADI-2 Pro series & DAC, Digiface USB/AES/Dante/Ravenna, UFX II/III, USB.IO, USB.MADI
Update to version: (*latest changes)
MADIface XT: USB 3/2 191, PCIe 56, DSP 42
MADIface XT II: USB 3/2 324, DSP 61, CC 15
MADIface USB, Hw Rev 6: 25, CC 4
MADIface USB, Hw Rev 7: 102, CC 103
MADIface Pro: 73
OctaMic XTC: USB 47, DSP 26
ADI-2/4 Pro SE (Hw Rev 6): FPGA 73, DSP 40
ADI-2/4 Pro SE (Hw Rev 7): FPGA 210, DSP 40
ADI-2/4 Pro EX: FPGA 324, DSP 106
ADI-2 Pro Series (Hw Rev 6): FPGA 270, DSP 130*
ADI-2 Pro EX (Hw Rev 7): FPGA 418, DSP 130*
ADI-2 DAC FS: FPGA 81, DSP 62
Digiface USB, Hw Rev X: 18, CC 2
Digiface USB, Hw Rev G: 35, CC 7
Fireface UFX II, Hw Rev A: USB 26, DSP 30, CC 15
Fireface UFX II, Hw Rev E: USB 115, DSP 30, CC 112
Fireface UFX II, Hw Rev 7: USB 206, DSP 30, CC 208
Fireface UFX III: USB 21 DSP 25 CC 47
Digiface Dante: 68 CC 21
Digiface Ravenna: 55 CC 3*
Digiface AES: USB 47, MCU 17, CC 11
USB I/O: USB 10 CC 14
USB.MADI: USB 18, CC 13*
Release date
2026-09-02
Windows Flash Update Tool for MADIface XT/XT II/USB/Pro, OctaMic XTC, ADI-2 Pro series & DAC, UFX II/III, UFX+, Digiface USB/Dante/Ravenna/AVB, USB.IO, USB.MADI
Update to firmware: (* latest change)
MADIface XT: USB 191 PCIe 56 DSP 42
MADIface XT II: USB 3/2 323, DSP 61, CC 17
MADIface USB: 25 CC4 (6), 102 CC 103 (7)
MADIface Pro: 73
OctaMic XTC: 47/26
ADI-2 Pro series: FPGA 270, DSP 130*
ADI-2 Pro EX: FPGA 418, DSP 130
ADI-2 DAC series: FPGA 81, DSP 62
ADI-2/4 Pro SE (6): FPGA 73, DSP 40
ADI-2/4 Pro SE (7): FPGA 210, DSP 40
UFX II: USB 26 DSP 30 CC 15 (A), USB 115 DSP 30 CC 112 (E), USB 206 DSP 30 CC 208 (7)
UFX+: USB 55 DSP 62 Thunderbolt 112 (A), USB 72 DSP 62 Thunderbolt 167 (E)
Digiface USB: 18 CC 2 (X), 35 CC 7 (G)
Digiface AVB: 273*
Digiface AES: USB 47 MCU 17 CC 11
USB I/O: USB 10, CC 14
Release date
2026-09-02
Mac OS X
Release date
Download
macOS 11 or up USB Series DriverKit Driver
macOS 11 or up (Big Sur, Monterey, Ventura and up) Check OS Version USB series DriverKit driver, v. 4.34.
Please read carefully how to install Intel & M1 & up Driver for RME Audio Interfaces
Release date
2026-11-10
MADIface Pro: 73
Release date
2026-09-02
macOS 11 and up USB Series Kernel Extension Driver
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.39. Supports Intel and Mx.
Release date
2026-06-06
macOS 10.12 up to 10.15 driver for Fireface UFX / UFX+ / UFX III, UFX II, 802, UCX, UCX II, UC, Babyface, Babyface Pro, MADIface XT/USB/Pro, Digiface USB/AES/Dante/Ravenna
Version 3.224. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. M users please download macOS 11 and up USB Series Driver.
Release date
2026-06-05
Mac OS X driver for Fireface UFX / UFX+ / UFX II, 802, UCX, UCX II, UC, Babyface, Babyface/Pro, MADIface XT / USB / Pro, Digiface USB - Legacy Build
Version 2.24. Compatible to 10.9 (OS X Mavericks) up to 10.13 (macOS High Sierra) Check OS Version. Legacy build, newer drivers are version 3.x. M user please download macOS 11 and up USB Series Driver.
Release date
2026-02-18
Windows
Release date
Download
MADIface Pro: 73
OctaMic XTC: 47/26
Digiface AVB: 273*
Release date
2026-09-02
Windows 10
Release date
Download
x64 / Arm 64 bit driver for Windows 10 and up, MADIface USB series
Driver for Windows 10 / 11, Intel x64 and Arm, version 1.0.29. Supports Intel Windows 10 or up 64 bit, and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Release date
2026-11-09
Windows USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna, USB.IO
Version 0.9845, Windows 8 and up. Last version to support Windows 32 bit.
Release date
2024-12-18
Windows 11
Release date
Download
Release date
2026-11-09
Release date
2024-12-18
Windows 7
Release date
Download
Windows 7 USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna
Version 0.9827, last driver version for Windows 7.
Release date
2023-09-13
Windows 8
Release date
Download
Release date
2024-12-18
Mac OS X
Release date
Download
TotalMix FX 2.x Mac, Installer, latest version
TotalMix FX V 2.10 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Mac, v 1.99 (single file download)
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Download
tmfx_mac_199.zip
TotalMix Remote Mac
Release date
2024-10-17
WAV File Batch Processor V 1.31 Mac
Multichannel WAV File Batch Processor[nbsp]- Converter for single and consecutive multichannel WAV files as recorded by the Fireface UFX, UFX II, UFX+ and UCX II Direct USB Recording function
Release date
2022-09-13
Windows
Release date
Download
TotalMix FX Windows 32 bit, v1.99 (single file download)
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
TotalMix Remote Windows
Release date
2024-10-17
WAV File Batch Processor V 1.31 Windows
Multichannel WAV File Batch Processor - Converter for single and consecutive multichannel WAV files as recorded by the Fireface UFX, UFX II, UFX+ and UCX II Direct USB Recording function.
Release date
2022-09-13
Windows 10
Release date
Download
TotalMix FX 2.x Windows Installer, latest version
TotalMix FX V 2.10 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Windows 64 bit, v199 (single file download)
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
Release date
2025-05-05
Windows 11
Release date
Download
Release date
2026-10-22
TotalMix FX Arm64 v 1.99 (single file download)
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Release date
2025-05-05
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and Mx machines. DigiCheck NG V 0.93 requires macOS 10.13 (High Sierra) or up.
Release date
2025-05-26
DIGICheck 0.73 Mac
Release date
2017-09-14
Download
dc_073_mac.zip
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Windows 10
Release date
Download
DigiCheck NG Windows
Release date
2025-05-26
Windows 11
Release date
Download
Release date
2025-05-26
Windows Vista
Release date
Download
DIGICheck 4.53 (Works with all RME cards, except HDSPe RayDAT and AIO)
Stereo Level Meter, Multichannel Level Meter, Global Level Meter, Spectral Analyser, Vector Audio Scope, Correlation Meter, Totalyser, Bit Statistic & Noise, Global Record. ASIO support, multi-client operation, display of +dBFS levels, display of playback data, K-system, free reference/scale, third colour. New: Hardware Level Meter. RMS Slow and RLB weighting filter. Optional Correlator. Level meters vertical/horizontal. Presets with hotkeys. Support for Fireface 400, newer Fireface 800 drivers, HDSP series WDM driver. Record functionality Global Record. Compatible to HDSPe PCI and HDSPe MADI/MADIface
Release date
2008-09-02
Download
dc_453.zip
Windows XP SP2
Release date
Download
Release date
2008-09-02
Download
dc_453.zip
Back
Manuals
Fireface UFX II
Product
Description
Download PDF
Fireface UFX II
Manual for Fireface UFX II, version 2.2, 02/2026
Product Images
Back
