Digiface AVB
256-Channel 192 kHz USB Audio Interface
Connectivity and Features
Exploring new Ways to transport Audio
RME’s Digiface AVB showcases how audio can be transferred from a Mac or PC into the network and back using the AVB protocol stack. It allows to send up to 128 audio channels for record and playback at 48 kHz / 24 bit sampling frequency and 64 channels at 96 kHz (128 channels I/O AVB) or 32 channels at 192 kHz with quad speed (64 channels I/O AVB).
Channels are organized in streams of configurable size from 2 to 32 channels, which enables connections to all available AVB audio devices on the market (comprehensive compatibility tests pending). The accompanying software package comprises an AVDECC controller, which provides essential functions to discover all AVB devices in a network and manage connections of incoming and outgoing streams. Basic monitoring capabilities are built in. TotalMix FX enables comprehensive routing and monitoring options.
TotalMix FX and TotalMix Remote
Like all the latest RME interfaces, the Digiface Series also includes the powerful digital real-time mixer TotalMix FX. It allows for practically unlimited mixing and routing operations, with all inputs and playback channels simultaneously, to any hardware outputs.
The Digiface Series includes a dedicated Control Room section with Talkback, Main/Phones, fader groups, mute groups, complete remote controllability via Mackie or OSC protocol, and much more. The Digiface Series does not support DSP based effects (FX) like EQ or reverb.
Additionally RME’s latest software, TotalMix Remote, enhances the power of RME interfaces by enabling remote control via iOS, PC or Mac. With a straightforward set up process — simply enter the IP address of the computer you would like to control with TotalMix Remote and get going — users can quickly adjust any aspect of TotalMix FX on a host system while walking around the studio with their tablet, or from a control room located elsewhere in the facility.
DigiCheck - Test, Measurement and Analysis Tool for Mac & Windows
The Interface comes with RME's unique software tool box for metering, testing, measuring and analyzing digital audio streams. On Mac OS X provides unique functions and features of the spectral analysis of the data calculated in hardware level right through to sophisticated multi-channel level meter. On Windows, an additional multi-track recorder and the display of playback data from an audio software are also available.
TotalMix FX - Mixing/Routing with superior features for Studio and Live Work
Since 2001 TotalMix added unlimited routing and mixing to RME‘s audio interfaces. Its unique capability to create as many independent submixes as output channels available turned it into the most flexible and powerful mixer of its kind.
RME USB - Transport audio with lowest latency and industry leading stability
Use your RME audio interface on Mac and PC with reliable, stable, and regularly updated drivers for our products. RME Audio develops its own interface core, it’s not dependent on 3rd parties for upgrades, modifications or bug fixes, so customers can use latest operating systems without interruption or delay."
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Specs
Digiface AVB
Gigabit Ethernet Port
- RJ45
- 100 Mbit/s, 1 Gbit/s
- Standard port LEDs: yellow connected, green data transmission
- Supports straight and crossover cables (Auto MDI-X)
- Up to 16 AVB audio streams
- AVDECC based exchange of status and control data
- Network-based remote control of the unit (TotalMix Remote)
Word Clock In
- BNC, not terminated (10 kOhm)
- Switchable internal termination 75 Ohm
- Automatic Double/Quad Speed detection and conversion to Single Speed
Word Clock Out
- BNC
- Max level: 5 Vss
- Level with termination 75 Ohm: 4.0 Vss
- Internal impedance: 10 Ohm
Output Analog Phones 33/34
- Dynamic range (DR): 110 dB RMS unweighted, 113 dBA
- Frequency response @ 44.1 kHz, -0.5 dB: 0 Hz – 20.8 kHz
- Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 45 kHz
- Frequency response @ 192 kHz, -1 dB: 0 Hz - 89 kHz
- THD @ -1 dBFS: - 96 dB, 0.0016 %
- THD+N @ -1 dBFS: -95 dB, 0.0017 %
- Channel separation: > 100 dB
- Output: 6.3 mm TRS jack, unbalanced
- Output impedance: 2 Ohm
- Output level at 0 dBFS, 1 kOhm load: +9.5 dBu
- Max power @ 0.1% THD: 50 mW
Digital
- Clocks: Internal, AVB, Word
- Supported sample rates: 44.1 kHz up to 192 kHz
General
- Power supply: USB bus power
- Typical power consumption: 1.5 Watts
- Current at 5 V bus power operation: 300 mA
- Max power consumption: 2 Watts (400 mA)
- Dimensions (WxHxD): 112 x 26 x 83 mm (4.41" x 1.02" x 3.27")
- Weight: 300 g (0.49 lbs)
- Temperature range: +5° up to +50° Celsius (41° F up to 122°F)
- Relative humidity: < 75%, non condensing
All specifications are subject to change without notice.
Drivers
Digiface AVB
Update to firmware: (* latest change)
MADIface XT: USB 191 PCIe 56 DSP 42
MADIface XT II: USB 3/2 323, DSP 61, CC 17
MADIface USB: 25 CC4 (6), 102 CC 103 (7)
MADIface Pro: 73
OctaMic XTC: 47/26
ADI-2 Pro series: FPGA 270, DSP 130*
ADI-2 Pro EX: FPGA 418, DSP 130
ADI-2 DAC series: FPGA 81, DSP 62
ADI-2/4 Pro SE (6): FPGA 73, DSP 40
ADI-2/4 Pro SE (7): FPGA 210, DSP 40
ADI-2/4 Pro EX: FPGA 324, DSP 106
UFX II: USB 26 DSP 30 CC 15 (A), USB 115 DSP 30 CC 112 (E), USB 206 DSP 30 CC 208 (7)
Fireface UFX III: USB 21 DSP 25 CC 47
UFX+: USB 55 DSP 62 Thunderbolt 112 (A), USB 72 DSP 62 Thunderbolt 167 (E)
Digiface USB: 18 CC 2 (X), 35 CC 7 (G)
Digiface AVB: 273*
Digiface Dante: 68 CC 21
Digiface Ravenna: 55
Digiface AES: USB 47 MCU 17 CC 11
USB I/O: USB 10, CC 14
USB.MADI: USB 18, CC 13*
Mac Firmware Update Tool for Digiface AVB, v 272.
Update to firmware revision UFX+: TB 110, DSP 46, USB 54 (AKM), TB 164, USB 68 (ESS). Digiface AVB: 244. Digiface Dante: 45.
macOS 11 or up (Big Sur, Monterey, Ventura and up) Check OS Version USB series DriverKit driver, v. 4.34.
Please read carefully how to install Intel & M1 & up Driver for RME Audio Interfaces |
Version 3.224 with added USB-Ethernet (network) driver. Compatible to 10.12 up to 10.15.x. Please also install the RME AVB Controller when using the Digiface AVB.
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.39. Supports Intel and Mx.
Version 3.224. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. M users please download macOS 11 and up USB Series Driver.
Note: This add-on is no longer needed. Please update the Digiface Dante to firmware 64 or up, Digiface AVB to firmware 268 or up.
Archived text: RME Network interface for Digiface AVB and Digiface Dante, for Mac OS X 10.14 and up, Intel/Mx compatible. See readme for important notes and usage.
MADIface Pro: 73
OctaMic XTC: 47/26
Digiface AVB: 273*
Driver for Windows 10 / 11, Intel x64 and Arm, version 1.0.31. Supports Intel Windows 10 or up 64 bit, and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Required network driver 0.9908 and AVB Controller 09908.129 for Digiface AVB. Optional internal network port driver 0.9908 for Digiface Dante.. For Windows 10 and up.
Mac AVB Controller installer, version 09929. netifc no longer included, use firmware 268 or up for Digiface AVB.
TotalMix FX V 2.10 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Version:[nbsp]09574. Outdated, please use the download RME AVB Package.
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
TotalMix FX V 2.10 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Universal binary, runs natively on Intel and Mx machines. DigiCheck NG V 0.93 requires macOS 10.13 (High Sierra) or up.
Manuals
Digiface AVB
Manual for Digiface AVB, version 1.41, 01/2021
