Digiface Dante
256-Channel 192 kHz USB Audio Interface
Digiface Dante
Products
Digiface Dante
The Digiface Dante is a lightweight, portable audio interface, combining Dante network connectivity and features with everything that RME is famous for: USB 3, MADI, TotalMix FX and outstanding options in both USB and stand-alone operation.
Adam Barber Creates Musical Sculptures for Top Hollywood Films
Artists
Barber has racked in film composer and musician credits in many major motion pictures, including music programmer for “Ghost Rider” and “Spiderman 3” and composer for “Last Shift” and “London Fields.”
More info
FOH | Broadcast Audio Engineer using the RME Digiface Dante
Artists
Ivan Talamantes is an experienced FOH and broadcast engineer with over 22 years in the industry, having worked with numerous artists and major U.S. churches.
More info
Connectivity and Features
RME USB 3.0
1 x Phones Output
TotalMix FX
ARC USB
Word Clock I/O
4 x Gigabit Ethernet (802.3 compliant)
1 x MADI I/O coaxial
DC-coupled Outputs (Phones)
Class Compliant Mode
Audinate’s Dante protocol combines with the industry-renowned reliability of RME Audio devices
Dante is an audio over IP protocol by Audinate. The Digiface Dante is a USB 3.0 from/to Dante interface, adding an external and fully mobile option to the internally used Dante PCIe card. Digiface Dante uses RME's matured MADIface Series driver for Windows and macOS, with lowest latency and industry leading stability. Equipped with the latest TotalMix FX it can not only route, but also mix as many independent submixes as outputs are available. The included high quality phones output offers a quick listen to any audio channel, but can also be used as line output to provide an additional analog stereo mixdown. Equipped with the largest Dante module 64 channel can be sent and received via network.
RME Audio AVB & Dante Solutions
AVB & Dante Network Solutions by RME Audio
RME made the two BNC sockets for word clock I/O switchable to MADI I/O, with up to 64 channels. The total sum of Dante and MADI, 128 channels, are transferred via USB 3.0 and handled via both Dante control software and RME's TotalMix FX, for full and struggle-free control of all audio.
Explore new Ways to transport Audio
Equipped with two banks of redundant network ports, the Digiface Dante is more than just an audio interface. It also offers the functionality of a switch, connecting up to 4 network lines, removing the need for further switches to distribute and collect network lines, or offers redundancy operation with 2-port connectivity for both the primary and secondary network.
Used without USB the Digiface Dante automatically turns into a 64-channel Dante / MADI converter. The analog stereo output can be preconfigured to send out a mix of exactly those channels that are needed. Full network redundancy and switch functionality are also available. With USB bus power operation and an external power supply connection a stable and redundant power supply is ensured. As Dante has become AES67 compatible, the Digiface Dante supports another format on the network side for even greater flexibility and more applications.
DIGICheck
TotalMix FX and TotalMix Remote
Like all the latest RME interfaces, the Digiface Series also includes the powerful digital real-time mixer TotalMix FX. It allows for practically unlimited mixing and routing operations, with all inputs and playback channels simultaneously, to any hardware outputs.
TotalMix Remote
The Digiface Series includes a dedicated Control Room section with Talkback, Main/Phones, fader groups, mute groups, complete remote controllability via Mackie or OSC protocol, and much more. The Digiface Series does not support DSP based effects (FX) like EQ or reverb.
Additionally RME’s latest software, TotalMix Remote, enhances the power of RME interfaces by enabling remote control via iOS, PC or Mac. With a straightforward set up process — simply enter the IP address of the computer you would like to control with TotalMix Remote and get going — users can quickly adjust any aspect of TotalMix FX on a host system while walking around the studio with their tablet, or from a control room located elsewhere in the facility.
DigiCheck - Test, Measurement and Analysis Tool for Mac & Windows
The Interface comes with RME's unique software tool box for metering, testing, measuring and analyzing digital audio streams. On Mac OS X provides unique functions and features of the spectral analysis of the data calculated in hardware level right through to sophisticated multi-channel level meter. On Windows, an additional multi-track recorder and the display of playback data from an audio software are also available.
TotalMix FX - Mixing/Routing with superior features for Studio and Live Work
Since 2001 TotalMix added unlimited routing and mixing to RME‘s audio interfaces. Its unique capability to create as many independent submixes as output channels available turned it into the most flexible and powerful mixer of its kind.
Find out More
RME USB - Transport audio with lowest latency and industry leading stability
Use your RME audio interface on Mac and PC with reliable, stable, and regularly updated drivers for our products. RME Audio develops its own interface core, it’s not dependent on 3rd parties for upgrades, modifications or bug fixes, so customers can use latest operating systems without interruption or delay."
Find out More
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
Specs
Digiface Dante
Gigabit Ethernet Port
  • RJ45
  • 100 Mbit/s, 1 Gbit/s
  • Standard port LEDs: yellow connected, green data transmission
  • Supports straight and crossover cables (Auto MDI-X)
  • Network-based remote control of the unit (TotalMix Remote)
MADI Input
  • Coaxial via BNC, 75 Ohm, according to AES10-1991
  • High-sensitivity input stage (< 0.2 Vpp)
  • Accepts 56 channel and 64 channel mode, plus 96k Frame
  • Standard: up to 64 channels 24 bit 48 kHz
  • S/MUX: up to 32 channels 24 bit 96 kHz
  • S/MUX4: up to 16 channels 24 bit 192 kHz
  • Lock range: 25 kHz – 54 kHz
MADI Output
  • Output voltage 400 mVpp
  • Cable length: up to 50 m
  • Generates 56 channel and 64 channel mode, plus 96k Frame
  • S/MUX / 96k Frame: up to 32 channels 24 bit 96 kHz
Word Clock In
  • BNC, not terminated (10 kOhm)
  • Switchable internal termination 75 Ohm
  • Automatic Double/Quad Speed detection and conversion to Single Speed
Word Clock Out
  • BNC
  • Max level: 5 Vss
  • Level with termination 75 Ohm: 4.0 Vss
  • Internal impedance: 10 Ohm
Digital
  • Clocks: Internal, Dante, Word, MADI
  • Supported sample rates: 44.1 kHz up to 192 kHz
All specifications are subject to change without notice.
Back
Drivers
Digiface Dante
Flash Update
Release date
Download
Mac OS Flash Update Tool for MADIface XT/XT II/USB/Pro, OctaMic XTC, ADI-2 Pro series & DAC, Digiface USB/AES/Dante/Ravenna, UFX II/III, USB.IO, USB.MADI
Update to version: (*latest changes)
MADIface XT: USB 3/2 191, PCIe 56, DSP 42
MADIface XT II: USB 3/2 324, DSP 61, CC 15
MADIface USB, Hw Rev 6: 25, CC 4
MADIface USB, Hw Rev 7: 102, CC 103
MADIface Pro: 73
OctaMic XTC: USB 47, DSP 26
ADI-2/4 Pro SE (Hw Rev 6): FPGA 73, DSP 40
ADI-2/4 Pro SE (Hw Rev 7): FPGA 210, DSP 40
ADI-2/4 Pro EX: FPGA 324, DSP 106
ADI-2 Pro Series (Hw Rev 6): FPGA 270, DSP 130*
ADI-2 Pro EX (Hw Rev 7): FPGA 418, DSP 130*
ADI-2 DAC FS: FPGA 81, DSP 62
Digiface USB, Hw Rev X: 18, CC 2
Digiface USB, Hw Rev G: 35, CC 7
Fireface UFX II, Hw Rev A: USB 26, DSP 30, CC 15
Fireface UFX II, Hw Rev E: USB 115, DSP 30, CC 112
Fireface UFX II, Hw Rev 7: USB 206, DSP 30, CC 208
Fireface UFX III: USB 21 DSP 25 CC 47
Digiface Dante: 68 CC 21
Digiface Ravenna: 55 CC 3*
Digiface AES: USB 47, MCU 17, CC 11
USB I/O: USB 10 CC 14
USB.MADI: USB 18, CC 13*
Release date
2026-09-02
Windows Flash Update Tool for MADIface XT/XT II/USB/Pro, OctaMic XTC, ADI-2 Pro series & DAC, UFX II/III, UFX+, Digiface USB/Dante/Ravenna/AVB, USB.IO, USB.MADI
Update to firmware: (* latest change)
MADIface XT: USB 191 PCIe 56 DSP 42
MADIface XT II: USB 3/2 323, DSP 61, CC 17
MADIface USB: 25 CC4 (6), 102 CC 103 (7)
MADIface Pro: 73
OctaMic XTC: 47/26
ADI-2 Pro series: FPGA 270, DSP 130*
ADI-2 Pro EX: FPGA 418, DSP 130
ADI-2 DAC series: FPGA 81, DSP 62
ADI-2/4 Pro SE (6): FPGA 73, DSP 40
ADI-2/4 Pro SE (7): FPGA 210, DSP 40
UFX II: USB 26 DSP 30 CC 15 (A), USB 115 DSP 30 CC 112 (E), USB 206 DSP 30 CC 208 (7)
UFX+: USB 55 DSP 62 Thunderbolt 112 (A), USB 72 DSP 62 Thunderbolt 167 (E)
Digiface USB: 18 CC 2 (X), 35 CC 7 (G)
Digiface AVB: 273*
Digiface AES: USB 47 MCU 17 CC 11
USB I/O: USB 10, CC 14
Release date
2026-09-02
Windows Flash Update Tool for Fireface UFX+, Digiface AVB, Digiface Dante - Nicht aktiv
Update to firmware revision UFX+: TB 110, DSP 46, USB 54 (AKM), TB 164, USB 68 (ESS). Digiface AVB: 244. Digiface Dante: 45.
Release date
2022-04-10
Mac OS X
Release date
Download
macOS 11 or up USB Series DriverKit Driver
macOS 11 or up (Big Sur, Monterey, Ventura and up) Check OS Version USB series DriverKit driver, v. 4.34.
Please read carefully how to install Intel & M1 & up Driver for RME Audio Interfaces
Release date
2026-11-10
MADIface Pro: 73
Release date
2026-09-02
macOS 10.12 to 10.15 driver for Digiface AVB and Dante
Version 3.224 with added USB-Ethernet (network) driver. Compatible to 10.12 up to 10.15.x. Please also install the RME AVB Controller when using the Digiface AVB.
Release date
2026-06-12
macOS 11 and up USB Series Kernel Extension Driver
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.39. Supports Intel and Mx.
Release date
2026-06-06
macOS 10.12 up to 10.15 driver for Fireface UFX / UFX+ / UFX III, UFX II, 802, UCX, UCX II, UC, Babyface, Babyface Pro, MADIface XT/USB/Pro, Digiface USB/AES/Dante/Ravenna
Version 3.224. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. M users please download macOS 11 and up USB Series Driver.
Release date
2026-06-05
RME Mac Network Interface for Digiface AVB and Digiface Dante
Note: This add-on is no longer needed. Please update the Digiface Dante to firmware 64 or up, Digiface AVB to firmware 268 or up.
Archived text: RME Network interface for Digiface AVB and Digiface Dante, for Mac OS X 10.14 and up, Intel/Mx compatible. See readme for important notes and usage.
Release date
2023-06-22
Windows
Release date
Download
MADIface Pro: 73
OctaMic XTC: 47/26
Digiface AVB: 273*
Release date
2026-09-02
Release date
2022-04-10
Windows 10
Release date
Download
Windows Network Driver for Digiface AVB /Dante and AVB Controller
Required network driver 0.9908 and AVB Controller 09908.129 for Digiface AVB. Optional internal network port driver 0.9908 for Digiface Dante.. For Windows 10 and up.
Release date
2026-11-09
x64 / Arm 64 bit driver for Windows 10 and up, MADIface USB series
Driver for Windows 10 / 11, Intel x64 and Arm, version 1.0.29. Supports Intel Windows 10 or up 64 bit, and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Release date
2026-11-09
Windows USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna, USB.IO
Version 0.9845, Windows 8 and up. Last version to support Windows 32 bit.
Release date
2024-12-18
Windows 11
Release date
Download
Release date
2026-11-09
Release date
2026-11-09
Release date
2024-12-18
Windows 7
Release date
Download
Windows 7 USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna
Version 0.9827, last driver version for Windows 7.
Release date
2023-09-13
Windows 8
Release date
Download
Release date
2026-11-09
Release date
2024-12-18
Mac OS X
Release date
Download
TotalMix FX 2.x Mac, Installer, latest version
TotalMix FX V 2.10 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Mac, v 1.99 (single file download)
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Download
tmfx_mac_199.zip
TotalMix Remote Mac
Release date
2024-10-17
Windows
Release date
Download
TotalMix FX Windows 32 bit, v1.99 (single file download)
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
TotalMix Remote Windows
Release date
2024-10-17
Windows 10
Release date
Download
TotalMix FX 2.x Windows Installer, latest version
TotalMix FX V 2.10 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Windows 64 bit, v199 (single file download)
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
Release date
2025-05-05
Windows 11
Release date
Download
Release date
2026-10-22
TotalMix FX Arm64 v 1.99 (single file download)
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Release date
2025-05-05
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and Mx machines. DigiCheck NG V 0.93 requires macOS 10.13 (High Sierra) or up.
Release date
2025-05-26
DIGICheck 0.73 Mac
Release date
2017-09-14
Download
dc_073_mac.zip
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Windows 10
Release date
Download
DigiCheck NG Windows
Release date
2025-05-26
Windows 11
Release date
Download
Release date
2025-05-26
Back
Manuals
Digiface Dante
Product
Description
Download PDF
Digiface Dante
Manual for Digiface Dante, version 2.1, 02/2026
Product Images
Back
