ADI-2 Pro FS R Black Edition
2-Channel high-end AD/DA Converter
Products
Ultra-Fidelity PCM/DSD 768 kHz AD/DA Converter
New Experience in Sound and Quality
RME’s reference AD/DA converter is a host of devices all put together into one unit, with a simple and mostly automated way of using it right out of the box. A unit with the industry’s biggest footprint per feature ratio, excellent tech specs, crystal clear and transparent sound signature, and two extremely powerful headphone outputs. The new ADI-2 Pro FS R Black Edition features the AK4493 chip, slightly improved specs and comes with the new extended Multi-Remote Control (MRC).
Connectivity and Features
1 x Stereo Analog I/O
1 x ADAT I/O
1 x SPDIF I/O
1 x AES I/O
RME USB 2.0
2 x Phones Output
Class Compliant Mode
Remote
SteadyClock FS
DC-coupled Outputs
RME's reference AD/DA converter is:
  • A high-end AD/DA converter in professional studio quality
  • A double headphone amplifier in true high-end quality
  • A USB DAC like no other - the most versatile and capable one
  • A high-end AD/DA frontend and headphone amp for iPad / iPhone
  • A multi-format converter (AES, SPDIF, ADAT) with monitoring function
  • A DSD record and playback solution
  • An AD/DA frontend for audio measurement at up to 768 kHz sample rate
Ultra-fidelity PCM/DSD 768 kHz AD/DA Converter
As the most flexible converter available, the ADI-2 Pro offers balanced/unbalanced analog I/Os, double Extreme Power headphone outputs, SteadyClock FS, 4-stage hardware input and output level control, DSP-based signal processing, external power supply operation, Class Compliant USB compatibility, sample rates up to 768 kHz as well as DSD record and Direct DSD playback (256 / 11.2 MHz).
Analog or Digital - Options Galore
The ADI-2 Pro includes two servo-balanced analog inputs on combo XLR / TRS jacks, two separate balanced and unbalanced outputs on XLR and TRS, two stereo Extreme Power headphone outputs on the front, an optical SPDIF I/O that also understands ADAT, and coaxial SPDIF (RCA) and AES I/O (XLR) via an included breakout cable. This universal set of I/O options offers superior quality and flexible connectivity to those who take a no-compromise approach to audio.
The USB 2.0 port is fully Class Compliant (UAC 2) for connection with compatible iOS devices, and is also used for firmware updates. Including an external switched power supply with lockable connector, the ADI-2 Pro can be easily powered from battery, opening up mobile applications as well as galvanically isolated use cases.
As a computer interface the ADI-2 Pro offers a stereo (2 in / 2 out) and a multichannel mode (6 in / 8 out). Compatibility with Mac OS X comes right out of the box. Under Windows the ADI-2 Pro uses RME's MADIface series driver, for full WDM and ASIO compatibility and highest performance.
ADI-2 Pro FS r
Perfect Sound Capture and Reproduction
Aiming for the absolute reference sound, any detail in the ADI-2 Pro is special and has its own story. The main PCB is an extraordinary 10 layer design with custom copper thickness, guaranteeing finest undisturbed sound as well as ample but separated power for the phones outputs. Internal power supply stages and precise regulators use a super-low-noise design to not degrade performance through the power rails. Selected SoundPlus operational amplifiers maintain highest SNR, lowest THD and high slew rate under all conditions. The whole analog circuit design is fully symmetrical and balanced throughout - and DC-coupled. The only capacitors in the signal path perform DC protection at the analog input sockets, and have been carefully selected to avoid any sonic impact.
The 4-channel AD-converter, supporting 768 kHz sample rate and DSD recording, is used in a dual mono design, with 3 dB improved signal to noise ratio. Two premium DACs are used for two separate stereo outputs. Internal audio processing like EQs, Crossfeed and spectral analysis, is done by a high performance DSP with 2.17 Giga FLOPS (2882 MIPS), delivering enough computing power to work even at 768 kHz sample rate.
For easy operation a high quality Sample Rate Converter has been added, switchable to the AES or SPDIF input, solving any clocking problem between those. And RME’s latest SteadyClock FS technology ensures perfect jitter reduction and stable clocking, no matter if internal or external clocks are used.
High Resolution Display Operation
RME have incorporated many unique features, not found on any comparable devices, like 5-band parametric EQs for fully individual phones compensation, adjustable Bass/Treble controls with quick access, a binaural crossfeed function, adjustable loudness filter, selectable AD/DA filters, four discrete I/O reference levels, auto reference level setting, auto balanced phones mode, and many more. The display is not only used to control the unit, but also shows warning and guidance messages.
Professional features such as M/S Processing, stereo width and phase reversal up to full control and storage of all settings are included, as well as RME’s famous Spectral Analyzer, a 30-band biquad filtered analysis tool offering unprecedented musical visualization, perfectly complementing the high-resolution IPS display.
Extreme Power Headphone Outputs
There is no use in boasting about -110 dB THD, when such values are not available in real world operation - for example when a 32 ohm headphone is connected. RME's engineers therefore designed a new headphone output stage that brings the full performance of the premium DAC to the phone jack - even when using low impedance headphones. The Extreme Power design excels with 0.1 Ohm output impedance, a maximum output level of +22 dBu, and a maximum output power of 1.5 Watts - per channel! The two, fully separated stereo headphone outputs deliver the same 120 dBA SNR performance as the line outputs, for a full hum and noise free listening experience. THD is far below -100 dB (0.001%) even at full power, for the most clear and detailed soundstage possible. The Extreme Power design also incorporates current limiting, power surveillance, overload detection and DC protection. A low power mode and a high power mode are provided, for a perfect match from IEM up to planar.
Having two stereo outputs, balanced headphone operation is possible. As RME's engineers were not satisfied with the existing techniques they developed a new Advanced Balanced mode for the ADI-2 Pro, that removes most limitations of standard balanced operation, and turns this mode into a a fully new experience. The exclusive Advanced Balanced mode delivers a balanced signal path from the DAC straight to the phone, with 3 dB gain in Signal to Noise Ratio, smoothed out deviations in components, optimized frequency response, super low output impedance (0.2 Ohms), and a maximum output level of +28 (twenty eight) dBu.
The Reference Converter
The ADI-2 Pro is RME’s reference AD/DA converter, USB DAC, USB interface and headphone amp. It’s numerous use cases make it an ideal choice in many fields, from the home user appreciating innovative solutions offering highest sound quality, the studio owner asking for reference AD/DA conversion, the Hi-Fi enthusiast demanding a flexible yet high-end headphone amplifier, up to the industry using the portable device as front-end for measurement systems.
SteadyClock FS - Reference class Digital Clocking
Excellent performance in all clock modes and High Quality Analog Conversion to hear your mix as it is, with lowest jitter and highest jitter immunity.
Find out more
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
ADI-2 Remote
The ADI-2 Remote software controller offers a seamless and intuitive interface for managing various parameters of the ADI- 2 series devices.
Find out More
RME ADi-2 Series MRC Remote
New extended Multi-Remote Support (MRC)
The ADI-2 Pro remote control provides buttons for standby on/off, volume, balance, bass and treble, input selection (optical, coaxial, USB), mute, on/off loudness, bass/treble and EQ. In addition, there are four programmable buttons that provide access to 52 different functions and commands for maximum flexibility. There is no other converter or comparable device with such a sophisticated, easy to use and at the same time versatile remote control!
Accessories
Specs
Analog Inputs
XLR
  • Input: XLR, servo-balanced
  • Input impedance balanced: 18 kOhm, unbalanced: 9 kOhm
  • Input sensitivity switchable +24 dBu, +19 dBu, +13 dBu, +4 dBu @ 0 dBFS
  • Digital Trim Gain range: 0 dB up to +6 dB
  • Signal to Noise ratio (SNR) @ +13/19/24 dBu: 120 dB RMS unweighted, 124 dBA
  • Signal to Noise ratio (SNR) @ +4 dBu: 119 dB RMS unweighted, 123 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 5 Hz – 20.5 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 3 Hz – 45.5 kHz
  • Frequency response @ 192 kHz, -1 dB: 2 Hz – 92.7 kHz
  • Frequency response @ 384 kHz, -1 dB: < 1 Hz – 124 kHz
  • Frequency response @ 768 kHz, -3 dB: < 1 Hz – 180 kHz
  • THD @ -1 dBFS: -116 dB, 0.00016 %
  • THD @ -10 dBFS: -125 dB, 0.000056 %
  • Channel separation: > 110 dB
TRS
As input XLR, but:
  • Input: 6.3 mm TRS jack, servo-balanced, fully compatible to TS and RCA
Analog Outputs
1/2 XLR
  • Output level switchable +24 dBu, +19 dBu, +13 dBu, +4 dBu @ 0 dBFS
  • Signal to Noise ratio (SNR) @ +4 dBu: 117 dB RMS unweighted, 120 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.2 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 44.9 kHz
  • Frequency response @ 192 kHz, -1 dB: 0 Hz – 88 kHz
  • Frequency response @ 384 kHz, -1 dB: 0 Hz – 115 kHz
  • Frequency response @ 768 kHz, -3 dB: 0 Hz – 109 kHz
  • THD @ 0 dBFS: < -120 dB, 0.0001 %
  • THD+N @ 0 dBFS: -115 dB, 0.00018 %
  • Output impedance: 200 Ohm
1/2 TRS (rear)
As output XLR, but:
  • Output: 6.3 mm TRS jack, impedance balanced
  • Maximum output level: +19 dBu
  • Signal to Noise ratio (SNR) @ +19 dBu: 120 dB RMS unweighted, 123 dBA
  • Signal to Noise ratio (SNR) @ +13 dBu: 118 dB RMS unweighted, 121 dBA
  • Signal to Noise ratio (SNR) @ +4 dBu: 115 dB RMS unweighted, 118 dBA
  • Output impedance: 100 Ohm unbalanced, 200 Ohm balanced
Phones 1/2
As Output 1/2 TS, but:
  • Output: 6.3 mm TRS jack, unbalanced, stereo
  • Output impedance: 0.1 Ohm
  • Signal to Noise ratio (SNR) @ +22 dBu: 120 dB RMS unweighted, 123 dBA
  • Signal to Noise ratio (SNR) @ +7 dBu: 118 dB RMS unweighted, 121 dBA
  • Output level at 0 dBFS, Ref Level +19 dBu, load 100 Ohm or up: +22 dBu (10 V)
  • Output level at 0 dBFS, Ref Level +4 dBu, load 8 Ohm or up: +7 dBu (1.73 V)
  • THD @ +18 dBu, 32 Ohm load, 1.2 Watt: -110 dB, 0.0003 %
  • THD+N @ + 18 dBu, 32 Ohm load: -107 dB, 0.00045 %
  • THD @ +14 dBu, 16 Ohm load, 0.94 Watt: -110 dB, 0.0003 %
  • Max power @ 0.001% THD: 1.5 W per channel
Output Phones 3/4
As Output Phones 1/2, but:
  • Output levels at 0 dBFS: Hi-Power off +7 dBu, Hi-Power On +22 dBu
Balanced Phones mode
As before, but:
  • Output levels at 0 dBFS: Hi-Power off +13 dBu (3.46 V), Hi-Power On +28 dBu (19.5 V)
  • Output impedance: 0.2 Ohm
  • Signal to Noise ratio (SNR) @ +28 dBu: 123 dB RMS unweighted, 126 dBA
  • Signal to Noise ratio (SNR) @ +13 dBu: 121 dB RMS unweighted, 125 dBA
  • Output level at 0 dBFS, Hi-Power On, load 150 Ohm or up: +28 dBu (19.5 V)
  • Output level at 0 dBFS, Hi-Power Off, load 8 Ohm or up: +13 dBu (3.46 V)
  • Max power @ 0.001% THD: 2.9 W per channel
Digital Inputs
General
  • Lock Range: 28 kHz – 200 kHz
  • Jitter suppression: > 50 dB (2.4 kHz)
  • Accepts Consumer and Professional format
AES/EBU
  • 1 x XLR, transformer-balanced, galvanically isolated, according to AES3-1992
  • Input sensitivity 1.0 Vpp
SPDIF coaxial
  • 1 x RCA, transformer-balanced, according to IEC 60958
  • High-sensitivity input stage (< 0.3 Vpp)
  • AES/EBU compatible (AES3-1992)
SPDIF optical
  • 1 x optical, according to IEC 60958
  • ADAT compatible
Digital Outputs
AES/EBU
  • Output level 2.7 Vpp
  • Format Professional according to AES3-1992 Amendment 4
  • Single Wire mode, sample rate 28 kHz up to 200 kHz
SPDIF coaxial
  • 1 x RCA, according to IEC 60958
  • Output level 0.75 Vpp
  • Format Consumer SPDIF according to IEC 60958
SPDIF optical
  • Format Consumer (SPDIF) according to IEC 60958
  • Sample rate 28 kHz up to 200 kHz
Digital
  • Clocks: Internal, AES In, SPDIF In, ADAT In
  • Jitter suppression of external clocks: > 50 dB (2.4 kHz)
  • Effective clock jitter influence on AD and DA conversion: near zero
  • PLL ensures zero dropout, even at more than 100 ns jitter
  • Additional Digital Bitclock PLL for trouble-free varispeed ADAT operation
  • Supported sample rates for external clocks: 32 kHz up to 200
  • Internally supported sample rates: 44.1 kHz up to 768 kHz
General
  • Included power supply: external switching PSU, 100 - 240 V AC, 2 A, 24 Watts
  • Standby power consumption: 50 mW
  • Idle power consumption: 10 Watts, Max. power consumption: 22 Watts
  • Idle current at 12 V: 850 mA (10 Watts)
  • Dimensions (WxHxD): 215 x 44 x 130 mm (8.5" x 1.73" x 5.1")
  • Weight: 1.0 kg ( 2.2 lbs)
  • Temperature range: +5° up to +50° Celsius (41° F up to 122°F)
  • Relative humidity: < 75%, non condensing
All specifications are subject to change without notice.
Back
Drivers
Flash Update
Release date
Download
Mac OS Flash Update Tool for MADIface XT/XT II/USB/Pro, OctaMic XTC, ADI-2 Pro series & DAC, Digiface USB/AES/Dante/Ravenna, UFX II/III, USB.IO, USB.MADI
Update to version: (*latest changes)
MADIface XT: USB 3/2 191, PCIe 56, DSP 42
MADIface XT II: USB 3/2 324, DSP 61, CC 15
MADIface USB, Hw Rev 6: 25, CC 4
MADIface USB, Hw Rev 7: 102, CC 103
MADIface Pro: 73
OctaMic XTC: USB 47, DSP 26
ADI-2/4 Pro SE (Hw Rev 6): FPGA 73, DSP 40
ADI-2/4 Pro SE (Hw Rev 7): FPGA 210, DSP 40
ADI-2/4 Pro EX: FPGA 324, DSP 106
ADI-2 Pro Series (Hw Rev 6): FPGA 270, DSP 130*
ADI-2 Pro EX (Hw Rev 7): FPGA 418, DSP 130*
ADI-2 DAC FS: FPGA 81, DSP 62
Digiface USB, Hw Rev X: 18, CC 2
Digiface USB, Hw Rev G: 35, CC 7
Fireface UFX II, Hw Rev A: USB 26, DSP 30, CC 15
Fireface UFX II, Hw Rev E: USB 115, DSP 30, CC 112
Fireface UFX II, Hw Rev 7: USB 206, DSP 30, CC 208
Fireface UFX III: USB 21 DSP 25 CC 47
Digiface Dante: 68 CC 21
Digiface Ravenna: 55 CC 3*
Digiface AES: USB 47, MCU 17, CC 11
USB I/O: USB 10 CC 14
USB.MADI: USB 18, CC 13*
Release date
2026-09-02
Windows Flash Update Tool for MADIface XT/XT II/USB/Pro, OctaMic XTC, ADI-2 Pro series & DAC, UFX II/III, UFX+, Digiface USB/Dante/Ravenna/AVB, USB.IO, USB.MADI
Update to firmware: (* latest change)
MADIface XT: USB 191 PCIe 56 DSP 42
MADIface XT II: USB 3/2 323, DSP 61, CC 17
MADIface USB: 25 CC4 (6), 102 CC 103 (7)
MADIface Pro: 73
OctaMic XTC: 47/26
ADI-2 Pro series: FPGA 270, DSP 130*
ADI-2 Pro EX: FPGA 418, DSP 130
ADI-2 DAC series: FPGA 81, DSP 62
ADI-2/4 Pro SE (6): FPGA 73, DSP 40
ADI-2/4 Pro SE (7): FPGA 210, DSP 40
UFX II: USB 26 DSP 30 CC 15 (A), USB 115 DSP 30 CC 112 (E), USB 206 DSP 30 CC 208 (7)
UFX+: USB 55 DSP 62 Thunderbolt 112 (A), USB 72 DSP 62 Thunderbolt 167 (E)
Digiface USB: 18 CC 2 (X), 35 CC 7 (G)
Digiface AVB: 273*
Digiface AES: USB 47 MCU 17 CC 11
USB I/O: USB 10, CC 14
Release date
2026-09-02
Mac OS X
Release date
Download
MADIface Pro: 73
Release date
2026-09-02
Windows
Release date
Download
MADIface Pro: 73
OctaMic XTC: 47/26
Digiface AVB: 273*
Release date
2026-09-02
Windows 10
Release date
Download
x64 / Arm 64 bit driver for Windows 10 and up, MADIface USB series
Driver for Windows 10 / 11, Intel x64 and Arm, version 1.0.31. Supports Intel Windows 10 or up 64 bit, and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Release date
2026-11-11
Windows USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna, USB.IO
Version 0.9845, Windows 8 and up. Last version to support Windows 32 bit.
Release date
2024-12-18
Windows 11
Release date
Download
Release date
2026-11-11
Release date
2024-12-18
Windows 7
Release date
Download
Windows 7 USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna
Version 0.9827, last driver version for Windows 7.
Release date
2023-09-13
Windows 8
Release date
Download
Release date
2024-12-18
Mac OS X
Release date
Download
ADI-2 Series Remote for macOS
Remote, backup and editing app for the ADI-2 series for macOS, v 2.2. Requires latest firmware update!
Release date
2026-10-22
ADI-2 Series Remote MIDI protocol (for developers)
For developers: the MIDI protocol[nbsp] as used in the ADI-2 Remote. This is NOT an app!
Release date
2023-10-01
Windows
Release date
Download
Release date
2023-10-01
Windows 10
Release date
Download
ADI-2 Series Remote for Windows
Remote, backup and editing app for the ADI-2 series for Windows, v 2.2. Requires latest firmware update, and MADIface series USB driver 0.9827 or higher!
Release date
2026-10-22
Release date
2023-10-01
Windows 11
Release date
Download
Release date
2026-10-22
Release date
2023-10-01
Windows 7
Release date
Download
Release date
2023-10-01
Windows 8
Release date
Download
Release date
2023-10-01
Windows Vista
Release date
Download
Release date
2023-10-01
Windows XP SP2
Release date
Download
Release date
2023-10-01
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and Mx machines. DigiCheck NG V 0.93 requires macOS 10.13 (High Sierra) or up.
Release date
2025-05-26
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Windows 10
Release date
Download
DigiCheck NG Windows
Release date
2025-05-26
Windows 11
Release date
Download
Release date
2025-05-26
Back
Manuals
Product
Description
Download PDF
ADI-2 Pro FS R
ADI-2 Pro FS Black Edition manual, version 3.8, 11/2023
ADI-2 Remote
ADI-2 Remote manual, version 2.2, 07/2026
Product Images
Media Material
Additional Downloads
Back
