M-1620 Pro
16 channel A/D, 20 channel D/A converter with ADAT, Milan®, MADI
The RME M-1620 Pro converts 16 analog line-level signals (per channel switchable up to +24 dBu) to and from MADI, ADAT and Milan network technology. This innovative unit is designed with a newly developed front panel that combines LED level meters with a display and includes two separate headphone outputs for monitoring - all within a single-height 19-inch rack device. Cutting-edge converters and flexible internal routing place it at the forefront of any audio network.
HDSPe AoX-M
512-Channel PCI Express Card with Milan & optional MADI
The HDSPe AoX PCIe x4 audio interface cards combine dual network ports with headphone output, AES3, MIDI, and internal expansion headers for up to four MADI ports. Whether used in a Thunderbolt™ expansion chassis or built into DAWs or audio processors, these cards send and receive up to 512 channels of audio and provide numerous mixing and routing capabilities.
12Mic
12-channel digitally controlled microphone preamplifier with AVB & MADI
The RME 12Mic is a twelve channel remote controllable microphone preamplifier with no-compromise A/D conversion, integrated AVB, ADAT and MADI connectivity, and a multitude of features designed to make it a perfect companion for any professional recording.
