Customer Information – macOS 26 Tahoe Compatibility
With the release of macOS 26 ("Tahoe"), Apple has removed system-level support for FireWire audio devices. As a result, RME FireWire interfaces such as the Fireface 800 and Fireface 400 can no longer be used under this operating system.
The required FireWire driver infrastructure is no longer available in macOS, and therefore no driver updates or workarounds are possible. Users depending on FireWire-based RME interfaces should remain on macOS 15 Sequoia or earlier, or consider migrating to a current RME USB Interface solution.
All RME USB, PCIe and Thunderbolt devices remain fully supported under macOS 26.
FireWire Support Ends — Your Fireface Still Has More to Give
Both the Fireface 800 and 400 feature ADAT connectivity, allowing you to repurpose them as high-quality converters. Simply connect them to a current RME interface, and you can expand your system with extra analog inputs and outputs. Perfect for studios that always need more flexibility!
Support
Check your macOS version
Here you will find an overview of the individual macOS versions and compatible RME USB drivers.
More Info
Support
Where can I find the macOS System Report
Find the system information about your Mac and check if your switched on interface is connected.
More Info
Support
RME Support
RME bietet Ihnen Telefon- und E-Mail-Support.
Vor einer direkten Anfrage studieren Sie bitte auch
unsere anderen Support-Rubriken, Tech Info
und Tutorial Websites.
All up-to-date Drivers
Firmware, Driver and Software Downloads for the current RME Audio product line.
More Info
