Fireface 802
60-Channel USB & FireWire Audio Interface
Fireface 802
Products
Fireface 802
60-Channel 192 kHz USB/FireWire Audio Interface
The Fireface 802 renews RME’s reputation built on the legendary Fireface 800. 60 channels of audio, high-end microphone preamps, reference class converters, a complete effects section and operation at up to 192 kHz are the base for many more features
Pegasus Musikproduktion
Artists
Berlin based company Pegasus Musikproduktion was founded in 2014 by Florian B. Schmidt and Aki Matusch. With first-rate mobile equipment they are producing premium music recordings all over europe.
More info
Connectivity and Features
12 x Analog I/O
4 x XLR/TRS Mic/Inst/Line
2 x Phones Output
1 x AES/EBU I/O
2 x ADAT I/O
1 x Word Clock I/O
1 x MIDI I/O
FireWire or USB operation
Class Compliant Mode
TotalMix FX
ARC USB
RME USB 2.0
Including FX
A legend Reborn
Ultra-low latency operation with USB or FireWire, combined with the legendary RME driver stability and maintenance. Active jitter suppression, individually switchable reference levels for all inputs and outputs, full stand-alone functionality, RME’s unique DIGICheck metering and analysis toolbox, and identical operation on Windows PC and Mac.
TotalMix FX, RME’s digital high-end mixer and signal router, driven by two powerful DSPs, with integrated EQ, Dynamics and Reverb/Echo effects at up to 192 kHz, plus a built-in monitoring controller.
TotalMix FX DSP Effects
TotalMix FX includes a complete effects system: EQ, Reverb, Dynamics & Delay
The full-blown feature set also includes optional Class Compliant mode and operation with TotalMix FX for iPad, RME’s app to fully control the 802 from the iPad, without any computer. The easy to use app includes metering for all 90 channels plus effects bus, different setup screens, and complete control of all features.
The Fireface 802 is a highly integrated pro audio solution, a full-blown studio, all within a 19” enclosure. An interface designed for users who don’t want to make compromises in sound, stability and ultra-low latency operation, and who long for an unrivaled professional feature set. Once again a milestone interface from RME, including the best of the best and even a bit more.
Free Software with any RME Audio Interface
Inputs and Outputs
The Fireface 802 provides 60 channels of audio: 30 input and 30 output channels. All inputs and outputs can be used at the same time. Up to 12 analog and 18 digital channels can be recorded onto 30 tracks separately.
Available I/Os (channels) with various sample rates:
Sample Rate Analog AES/EBU ADAT Total In/Out
44.1/48 kHz 12/12 2/2 16/16 30/30
88.2/96 kHz 12/12 2/2 8/8 22/22
176.4/192 kHz 12/12 2/2 4/4 18/18
Analog I/O
The Fireface 802 has 12 analog I/Os.
12 Inputs
8 balanced TRS on the back and 4 XLR inputs with Mic/Instrument preamps on the front.
12 Outputs
On the rear: 8 balanced TRS. On the front: Two hi-power TRS stereo phones outputs provide high volumes even with hi-impedance headphones (playback channels 9/10 and 11/12).
Capture every detail with latest digital conversion technology
Sound Quality
Like other RME products before the Fireface 802 combines excellent analog circuit design with latest digital conversion technology. All balanced TRS & XLR I/Os as well as the two phones outputs offer outstanding low noise and distortion values. In best RME tradition and product philosophy converters and preamps don’t produce “sound”, they do not add or remove anything from the source signal, just capture it as it is.
Equipped with the latest low latency A/D and D/A converter chips, all I/Os operate at up to 192 kHz and reach 118 dBA dynamic range on playback - even both headphone outputs. Their high power technology delivers high volume no matter if high or low impedance phones are used.
Due to its efficient jitter reduction, RME’s superior SteadyClock guarantees state-of-the-art AD/DA conversion, even when clocking to an external clock source.
Every input and output is individually switchable to these common professional studio levels: -10 dBV, +4 dBu, HiGain (equivalent to +2 dBV, +13 dBu and +19 dBu for digital full scale).
All outputs can be used for ASIO Direct Monitoring (ADM) purposes.
TotalMix FX
TotalMix FX - Digital high-end mixer and signal router
Professional high-transparency Preamps
For Microphones and Instruments with Low Latency Conversion. The 802 has four high-transparency preamps, also with low latency converters. Microphone and instrument preamps of the 802 use the classic technology of the OctaMic II, a high-end preamp for supreme sonic demands and critical applications, like the professional recording of classical concerts. The symmetrical preamp design impresses with extremely low distortion, excellent signal to noise ratio and a perfect linear frequency response. A premium solution for transmitting and amplifying any audio input truly unchanged, be it high-level stage or typical studio signals, lower level and high-impedance instruments, or dynamic, condenser and ribbon microphones.
The pot-controlled gain of up to 60 dB, adjustable over a range of 54 dB, is individually set for every preamp on the front of the 802.
The four inputs on the front use balanced XLR/TS combo sockets and operate alternatively as Hi-Z inputs. Directly plug in up to four guitars or other instruments - no other hardware required.
Each channel can be individually switched to 48V phantom power or instrument mode. LEDs for signal, clip, TS operation and activated phantom power provide overview on the unit's status.
The Fireface 802 follows RME's tradition of providing flexible and expandable audio systems. Adding additional preamplifiers or more analog inputs is easily done via the dual ADAT optical I/Os on the rear.
AES/EBU
The Fireface 802 has one professional AES/EBU I/O operating at up to 192 kHz.
ADAT
Two 8-channel ADAT I/Os allow for a connection of two additional AD/DA converters or the insertion of effects devices and mixing consoles. Both I/Os support sample rates at up to 192 kHz (S/MUX4). Like AES/EBU, these 16 ADAT channels are available simultaneously with the analog channels. Using two external converters like the ADI-8 QS, the 802 will provide 28 analog inputs and outputs, 20 with a sample rate of 96 kHz, and still 16 at 192 kHz.
SPDIF
The second ADAT I/O can be used as optical SPDIF I/O, making the Fireface 802 connections even more flexible.
Word Clock & MIDI
A word clock input and output (BNC) with switchable termination and a MIDI I/O complete the list of connections, turning the Fireface 802 into a professional audio system with universal usability.
TotalMix FX - Mixing/Routing with superior features for Studio and Live Work
Since 2001 TotalMix added unlimited routing and mixing to RME‘s audio interfaces. Its unique capability to create as many independent submixes as output channels available turned it into the most flexible and powerful mixer of its kind.
Find out More
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
SteadyClock
RME's unique jitter suppression technology guarantees perfect sound quality throughout, making the device completely independent from the quality of external clock signals. Due to the highly efficient jitter reduction, the 802 converters operate independently from the quality of the external clock signal, as if they are working with internal clock all the time - guaranteeing a pristine sound quality!
SteadyClock allows the Fireface 802 to control the sample rate freely on its own. The settings dialog includes a direct choice of the video and audio world's most often used sample rates.
ICC - Intelligent Clock Control
Not only displays every clock status, but will also retain the last valid input sample rate in case of failure of the external source. Other renowned RME technologies like SyncCheck offer a quick detection of clock problems.
DIGICheck
The 802 comes with RME´s unique software tool box for metering, testing, measuring and analyzing digital audio streams. It provides a multi-track recorder, calculates the level meters peak and RMS in hardware, and analyzes and displays audio in multiple ways, like stereo, multichannel, all channels, surround, spectral, and many more.
Power supply
The specially developed, internal hi-performance switch mode power supply lets the 802 operate in the range of 100V to 240V AC, thus can be operated all over the world. It is short-circuit proof, has an integrated line-filter, is fully regulated against voltage fluctuations, and suppresses mains interference.
Stand Alone Operation with Setup Recall
The Fireface 802 can be set up and configured directly via iPad, MIDI remote and ARC. Additionally 6 memory slots are present where the current configuration can be stored permanently. This way the 802 operates independently from a computer. In stand-alone operation it can turn itself into different devices by the simple push on a button.
Specs
Fireface 802
AD, Line In 1-8, rear
  • Resolution AD: 24 bit
  • Signal to Noise ratio (SNR): 113 dB RMS unweighted, 116 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 5 Hz - 20.8 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 5 Hz - 45.8 kHz
  • Frequency response @ 192 kHz, -1 dB: 5 Hz - 92 kHz
  • THD: < -110 dB, < 0.00032 %
  • THD+N: < -104 dB, < 0.00063 %
  • Channel separation: > 110 dB
  • Input: 6.3 mm TRS jack, electronically balanced
  • Input sensitivity: 8 kOhm unbalanced, 12 kOhm balanced
  • Input sensitivity switchable to Lo Gain, +4 dBu, -10 dBV
  • Input level for 0 dBFS @ Lo Gain: +19 dBu
  • Input level for 0 dBFS @ +4 dBu: +13 dBu
DA - Stereo Monitor Output Phones (9-12)
As DA, but:
  • Output: 6.3 mm TRS stereo jack, unbalanced
  • Maximum output level at 0 dBFS, High: +16.8 dBu
  • Maximum output level at 0 dBFS, Low: +2 dBV
  • Output impedance: 30 Ohm
AES/EBU
2 x XLR, transformer-balanced, galvanically isolated, according to AES3-1992
Microphone In 9-12, front
As AD, but:
  • Input: XLR, electronically balanced
  • Input impedance: 3.4 kOhm
  • Signal to Noise ratio (SNR): 112 dB RMS unweighted, 116 dBA
  • Gain range: 54 dB
  • Maximum input level, Gain +6 dB: +10 dBu
Instrument In 9-12, front
As AD, but:
  • Input: 6.3 mm TS jack, unbalanced
  • Input impedance: 800 kOhm
  • Signal to Noise ratio (SNR): 112 dB RMS unweighted, 115 dBA
  • Maximum input level, Gain +6 dB: +21 dBu
DA, Line Out 1-8, rear
  • Dynamic range (DR): 115 dB RMS unweighted, 118 dBA
  • Frequency response @ 44.1 kHz, -0.5 dB: 5 Hz - 20.8 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 5 Hz - 45 kHz
  • Frequency response @ 192 kHz, -1 dB: 5 Hz - 89 kHz
  • THD: -110 dB, < 0.00032 %
  • THD+N: -104 dB, < 0.00063 %
  • Output: 6.3 mm TRS jack, servo-balanced
  • Output impedance: 75 Ohm
  • Output level switchable Hi Gain, +4 dBu, -10 dBV
  • Output level at 0 dBFS @ Hi Gain: +19 dBu
  • Output level at 0 dBFS @ +4 dBu: +13 dBu
  • Output level at 0 dBFS @ -10 dBV: +2 dBV
ADAT Optical
  • 2 x TOSLINK I/O, format according to Alesis specification
  • Standard: 2 x 8 channels 24 bit, up to 48 kHz
  • Double Speed (S/MUX): 2 x 4 channels 24 bit 96 kHz
  • Quad Speed (S/MUX4): 2 x 2 channels 24 bit 192 kHz
  • Quad Speed Windows USB: 1 x 2 channels 24 bit 192 kHz
SPDIF optical (via ADAT2)
  • 1 x optical, according to IEC 60958
Word Clock
  • BNC, switchable termination
All specifications are subject to change without notice.
Back
Drivers
Fireface 802
Flash Update
Release date
Download
Mac OS Flash Update Tool for Fireface UFX, 802, UCX, UCX II, UC, Babyface/Pro
Update to version UFX: 361/163/344/29, 802 A: 20/9/9/12, 802 E: 112/101/101/9, 802 FS: 227/ 215/ 31, UCX: 49/260/27/14, UCX II (6): 43/36/21, UCX II (7): 106/36/104, UC: 127/138, Babyface: 226, Babyface Pro & FS: 211/322.
Release date
2025-09-01
Download
fut_usb_mac.zip
Windows Flash Update Tool for Fireface UFX, 802, UCX, UCX II, UC, Babyface Pro
Update to firmware revision UFX: 361/163/344/29, 802: 20/9/9/12 (A), 112/9/101/101 (E), 802 FS: 227/31/215, UCX: 49/260/27/14, UCX II (6): 43/36/21, UCX II (7): 106/36/104, UC: 127/138, Babyface: 226, Babyface Pro & FS: 211/322.
Release date
2025-09-01
Download
fut_usb_win.zip
Mac OS X
Release date
Download
macOS 11 or up USB Series DriverKit Driver+Fut
macOS 11 or up USB series DriverKit driver, v. 4.34.
Release date
2026-11-10
macOS 11 and up USB Series Kernel Extension Driver
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.39. Supports Intel and Mx.
Please read carefully how to install Intel & M1 & up Driver for RME Audio Interfaces
Release date
2026-06-06
macOS 10.12 up to 10.15 driver for Fireface UFX / UFX+ / UFX III, UFX II, 802, UCX, UCX II, UC, Babyface, Babyface Pro, MADIface XT/USB/Pro, Digiface USB/AES/Dante/Ravenna
Version 3.224. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. M users please download macOS 11 and up USB Series Driver.
Release date
2026-06-05
Mac OS X driver for Fireface UFX / UFX+ / UFX II, 802, UCX, UCX II, UC, Babyface, Babyface/Pro, MADIface XT / USB / Pro, Digiface USB - Legacy Build
Version 2.24. Compatible to 10.9 (OS X Mavericks) up to 10.13 (macOS High Sierra) Check OS Version. Legacy build, newer drivers are version 3.x. M user please download macOS 11 and up USB Series Driver.
Release date
2026-02-18
Release date
2025-09-01
Download
fut_usb_mac.zip
Windows
Release date
Download
Release date
2025-09-01
Download
fut_usb_win.zip
Windows 10
Release date
Download
x64 / Arm 64 bit driver for Windows 10 and up, Fireface USB series
Driver for Windows 10 / 11, Intel x64 and Arm, version 1.277. Supports Intel Windows 10 or up 64 bit and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Release date
2026-09-21
Windows USB driver for Fireface UFX, 802, UCX, UCX II, UC and Babyface/Pro
Version 1.253, for Windows 8 and up. Last version to support Windows 32 bit.
Release date
2024-10-17
Windows 11
Release date
Download
Release date
2026-09-21
Release date
2024-10-17
Windows 7
Release date
Download
Release date
2024-10-17
Windows 7 USB driver for Fireface UFX, 802, UCX, UCX II, UC and Babyface/Pro
Version 1.246, last driver for Windows 7.
Release date
2023-07-11
Windows 8
Release date
Download
Release date
2024-10-17
Windows XP SP2
Release date
Download
Last Windows XP SP2 PnP driver for Fireface Series and Babyface/Pro
Version1.093.
Release date
2016-07-22
Mac OS X
Release date
Download
TotalMix FX 2.x Mac, Installer, latest version
TotalMix FX V 2.10 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Mac, v 1.99 (single file download)
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Download
tmfx_mac_199.zip
TotalMix Remote Mac
Release date
2024-10-17
Windows
Release date
Download
TotalMix FX Windows 32 bit, v1.99 (single file download)
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
TotalMix Remote Windows
Release date
2024-10-17
Windows 10
Release date
Download
TotalMix FX 2.x Windows Installer, latest version
TotalMix FX V 2.10 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Windows 64 bit, v199 (single file download)
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
Release date
2025-05-05
Windows 11
Release date
Download
Release date
2026-10-22
TotalMix FX Arm64 v 1.99 (single file download)
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Release date
2025-05-05
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and Mx machines. DigiCheck NG V 0.93 requires macOS 10.13 (High Sierra) or up.
Release date
2025-05-26
DIGICheck 0.73 Mac
Release date
2017-09-14
Download
dc_073_mac.zip
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Windows 10
Release date
Download
DigiCheck NG Windows
Release date
2025-05-26
Windows 11
Release date
Download
Release date
2025-05-26
Windows Vista
Release date
Download
DIGICheck 4.53 (Works with all RME cards, except HDSPe RayDAT and AIO)
Stereo Level Meter, Multichannel Level Meter, Global Level Meter, Spectral Analyser, Vector Audio Scope, Correlation Meter, Totalyser, Bit Statistic & Noise, Global Record. ASIO support, multi-client operation, display of +dBFS levels, display of playback data, K-system, free reference/scale, third colour. New: Hardware Level Meter. RMS Slow and RLB weighting filter. Optional Correlator. Level meters vertical/horizontal. Presets with hotkeys. Support for Fireface 400, newer Fireface 800 drivers, HDSP series WDM driver. Record functionality Global Record. Compatible to HDSPe PCI and HDSPe MADI/MADIface
Release date
2008-09-02
Download
dc_453.zip
Windows XP SP2
Release date
Download
Release date
2008-09-02
Download
dc_453.zip
Flash Update
Release date
Download
Mac OS Flash Update Tool for Fireface UFX/UCX/802
Update to firmware[nbsp]344/27/7. Currently Fireface UFX/UCX/802 are updated via USB[nbsp]only. Please install the USB driver, then use the USB flash update which updates the FireWire firmware as well.
Release date
2016-01-26
Download
fut_usb_mac.zip
Windows Flash Update Tool for Fireface UFX/UCX/802
Update to firmware revision 344/27/7. Currently Fireface UFX/UCX/802 are updated via USB only. Please install the USB driver, then use the USB flash update which updates the FireWire firmware as well.
Release date
2016-01-26
Download
fut_usb_win.zip
Mac OS X
Release date
Download
macOS 11 or up FireWire Series Driver
Version 3.41, for macOS 11 or up. Supports Intel and Mx (Apple Silicon).
Release date
2021-11-10
Mac OS X FireWire driver for Fireface 400, 800, 802, UCX, UFX
Version 3.391. Compatible to OS 10.9 up to 10.15.
Release date
2021-09-22
Release date
2016-01-26
Download
fut_usb_mac.zip
Windows
Release date
Download
Windows 7 to 11 PnP FireWire driver for Fireface 400, 800, 802, UCX, UFX
Version 3.125.
Release date
2019-02-27
Release date
2016-01-26
Download
fut_usb_win.zip
Windows XP SP2
Release date
Download
Last Windows XP SP2 PnP driver Version 3.118.
Release date
2017-07-22
Back
Manuals
Fireface 802
Product
Description
Download PDF
Fireface 802
Latest manual for Fireface 802, version 2.0, 10/2022
Product Images
Back
No longer available and replaced by the new Fireface 802 FS
