HDSP 9632
32-Channel PCI Card with Multi-Format I/O
HDSP 9632
Products
HDSP 9632
RME presents the world's most versatile PCI Audio Interface - the Hammerfall DSP 9632. This card makes the dream of an All-In-One solution for every possible application come true.
Connectivity and Features
1 x Stereo Analog I/O
1 x ADAT I/O
1 x SPDIF I/O
1 x Phones Output
1 x MIDI I/O
ARC USB
TotalMix FX
DC-coupled Outputs (Phones)
As usual, RME has not made any compromises: Latest 192 kHz AD- and DA-converters with more than 110 dB signal to noise ratio, all inputs and outputs simultaneously operational, easy-to-install optional hi-quality analog expansion boards, the famous TotalMix FX, a newly developed sensational clock section with maximum jitter suppression of external clock signals - all this combines into a 'soundcard' that the world has been waiting for so long. A PCI Express version (HDSPe AIO) is available.
Free Software for all RME Audio Interfaces
Features
The HDSP 9632 provides unique features:
  • Balanced stereo analog in- and output, 24-Bit/192kHz, > 110 dB SNR
  • Optional analog expansion boards with 4 balanced in- or outputs
  • All analog I/Os capable of 192 kHz, constant number of available channels
  • 1 ADAT digital I/O, supporting 96 kHz S/MUX operation
  • 1 SPDIF digital I/O, 192 kHz-capable
  • 1 Breakout cable for coaxial SPDIF*
  • Up to 16 I/Os can be used simultaneously!
  • 1 Stereo headphone output, parallel to the analog out, additional level settings
  • 1 MIDI I/O with 16 channels of hi-speed MIDI via breakout cable
  • DIGICheck, RMEs unique metering- and analysing tool
  • HDSP Meter Bridge: freely scalable level meters, peak- and RMS calculation directly in hardware
  • TotalMix: 512 channel Mixer with 40 Bit internal resolution
* The HDSP 9632 ships in a basic version including two RCA/phono breakout cables (headphone: TRS jack). Therefore all analog I/Os and the SPDIF I/O are unbalanced. XLR breakout cables are available as an option (headphone: Neutrik TRS locking jack), turning analog and AES/EBU into balanced mode.
HDSP 9632 debuts SteadyClock (TM), a newly developed clock technology, combining professional features like maximum jitter suppression at full varipitch capabilities and software controlled sample rates.
Compared to the well-known DIGI96/8 series, the HDSP 9632 not only offers a further improved analog interface, but also all the features of the award-winning Hammerfall DSP series: All inputs and outputs simultaneously available, MIDI I/O and TotalMix, the DSP-based real-time mixer/router. Hardware updates through software and driver updates are risk-free thanks to the Secure BIOS Technology.
In short: The HDSP 9632 is the ultimate audio interface for PC or Mac, digital or analog.
Accessories
  • HDSP 9632: Analog breakout cable, balanced (BO9632XLRMKH)
  • HDSP 9632: Analog breakout cable, unbalanced (BO9632CMKH)
  • HDSP 9632: Digital breakout cable, SPDIF (BO9632)
  • HDSP 9632: Digital breakout cable, AES/EBU & SPDIF (BO968)
Optional Add-Ons
AI4S-192 AIO and AO4S-192 AIO: 4-Channel analog I/O modules with 192 kHz support
Works with: HDSPe AIO, HDSP 9632
These options for the HDSP 9632 and HDSPe AIO are analog expansion boards, designed as bracket with 4 stereo TRS jacks each. AI4S-192 AIO provides four servo-balanced inputs, AO4S-192 AIO provides four servo-balanced outputs. With this a maximum of 6 (including the stereo I/O of the card) inputs and/or outputs can be achieved.
The converters offer the same performance as the on-board stereo analog I/O of the HDSPe AIO: up to 192 kHz, balanced connection and the choice of three different reference levels, selected in the Settings dialog.
Both modules can be used single or in combination. The display of the channels in TotalMix changes accordingly.
Note: AI4S-192 and AO4S-192 (without the suffix AIO) do work only with the HDSP 9632. The current Expansion Boards with the suffix AIO work with both cards.
More information can be found in the manuals:
Manual AI4S-192 AIO
Manual AO4S-192 AIO
Word Clock Module (WCM)
Wordclock Module
Works with: HDSPe RayDAT, HDSPe AIO, HDSP 9632
The Word Clock Module (WCM) provides a galvanically isolated word clock input and two word clock outputs (BNC connectors). Both outputs have their own driver stages, providing an extremely low jitter signal. A push switch activates 75 Ohms termination for the hi-impedance input. SteadyClock, part of the PCI card, guarantees an excellent performance in all clock modes. Its highly efficient jitter suppression refreshes and cleans up any clock signal, and provides it as reference clock at the two outputs.
Installation is done in a convenient manner using the supplied bracket. No PCI slot on the motherboard is required. The module is internally connected via a 10-pin connector and a flat ribbon cable to the PCI card. Thanks to several LEDs (power, termination, LOCK) and the highly integrated concept of installation, first operation and usage are simple even for the inexperienced user.
More information can be found in the HDSP 9632 WCM manual.
TDIF Expansion: HDSP 9632 supports also the TEB TDIF-I/O-Module (no longer available).
Expansion Boards Optional analog and digital I/Os.
Specs
HDSP 9632
  • Supported sample frequencies: Internally 32, 44.1, 48, 64, 88.2, 96, 176.4, 192 kHz. Externally 28 kHz - 200 kHz
  • 8 buffer sizes/latencies available: 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms, 186 ms
  • All settings changeable in real-time
  • Automatic and intelligent master/slave clock control
  • Enhanced Mixed mode: All inputs and outputs simultaneously operational
  • TMS (Track Marker Support): Supports CD/DAT start-IDs and the read out of CD subcode
  • Unique status windows for record and playback, showing mode and sample rate
  • DIGICheck, RMEs unique metering and analysing tool
  • Digital inputs and outputs ground-free transformer coupled
  • 3-stage hardware level control for analog inputs and outputs
  • Balanced analog input and output, DC-coupled signal path
  • 192 kHz / 24-Bit converters. SNR 110 dB RMS unweighted, 113 dBA
  • Maximum input and output level (0 dBFS @ HiGain): +19 dBu
  • Low impedance headphone output (75 ohm), stepless output level through software faders
  • Headphone Speaker Protection minimizes noise during power on/off
  • All inputs and outputs simultaneously operational
  • Super low jitter design: < 1 ns in all clock modes
All specifications are subject to change without notice.
Back
Drivers
HDSP 9632
Mac OS X
Release date
Download
TotalMix FX 2.x Mac, Installer, latest version
TotalMix FX V 2.10 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Mac, v 1.99 (single file download)
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Download
tmfx_mac_199.zip
TotalMix Remote Mac
Release date
2024-10-17
Windows
Release date
Download
TotalMix FX Windows 32 bit, v1.99 (single file download)
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
TotalMix Remote Windows
Release date
2024-10-17
Windows 10
Release date
Download
TotalMix FX 2.x Windows Installer, latest version
TotalMix FX V 2.10 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.10 or 1.991, when using an older or not yet updated driver package.
Release date
2026-10-22
TotalMix FX Windows 64 bit, v199 (single file download)
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
Release date
2025-05-05
Windows 11
Release date
Download
Release date
2026-10-22
TotalMix FX Arm64 v 1.99 (single file download)
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Release date
2025-05-05
Flash Update
Release date
Download
Windows Flash Update Tool (02/2009)
UpdatesPCI and CardBus card to hardware revision 17/55 HDSP 9652 to 108, HDSP 9632 to 155, HDSP MADI to 207 and AES-32 to 234. Flash Update Tool for Windows 2000/XP/Vista/7/8/10.
Attention: Users of HDSP PCI Rev. < 1.8 and the flat HDSP CardBus (15-pin connector) please carefully study the included readme before performing the flash update
Release date
2015-10-12
Download
fut_wdm_dsp.zip
Mac OS X
Release date
Download
Mac OS X Intel (10.4.8 or up) version of the PPC driver 1.6c for Hammerfall DSP System
Also supports HDSPe PCI Card and ExpressCard with Digiface, Multiface and RPM. Version 1.73. See readme.txt for important notes!
Release date
2008-06-22
Download
hdsp_173_x86.gz
Windows
Release date
Download
Release date
2015-10-12
Download
fut_wdm_dsp.zip
Windows 10
Release date
Download
x64 / Arm 64 bit driver for Windows 10 and up, HDSPe Series
Driver for Windows 10 / 11, Intel x64 and Arm, version 4.62. Supports Intel Windows 10 or up 64 bit and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Release date
2026-01-28
WDM/ASIO driver for HDSP/HDSPe cards/systems
WDM, WDM-KS and ASIO. Version 4.50. Windows XP SP3 / 8/10/11, not Windows 7. Supports all HDSP and HDSPe cards/systems except HDSPe MADI FX.
Release date
2025-01-16
Windows 11
Release date
Download
Release date
2026-01-28
Release date
2025-01-16
Windows 7
Release date
Download
WDM/ASIO driver for HDSP/HDSPe cards/systems - Windows 7
WDM, WDM-KS and ASIO. Version 4.36. Windows XP SP3 / 7/8/10. Supports all HDSP and HDSPe cards/systems except HDSPe MADI FX.
Release date
2020-12-10
Windows 8
Release date
Download
Release date
2025-01-16
Windows XP SP2
Release date
Download
Release date
2025-01-16
Release date
2020-12-10
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Windows 10
Release date
Download
DigiCheck NG Windows
Release date
2025-05-26
Windows 11
Release date
Download
Release date
2025-05-26
Windows Vista
Release date
Download
DIGICheck 4.53 (Works with all RME cards, except HDSPe RayDAT and AIO)
Stereo Level Meter, Multichannel Level Meter, Global Level Meter, Spectral Analyser, Vector Audio Scope, Correlation Meter, Totalyser, Bit Statistic & Noise, Global Record. ASIO support, multi-client operation, display of +dBFS levels, display of playback data, K-system, free reference/scale, third colour. New: Hardware Level Meter. RMS Slow and RLB weighting filter. Optional Correlator. Level meters vertical/horizontal. Presets with hotkeys. Support for Fireface 400, newer Fireface 800 drivers, HDSP series WDM driver. Record functionality Global Record. Compatible to HDSPe PCI and HDSPe MADI/MADIface
Release date
2008-09-02
Download
dc_453.zip
Windows XP SP2
Release date
Download
Release date
2008-09-02
Download
dc_453.zip
DIGICheck 2.90 (Works with all RME cards except HDSPe series)
DIGICheck for Windows 98/ME/NT/2000/XP, Version 2.90 from 4.12.01
Release date
2001-12-04
Download
digichck.zip
Back
Manuals
HDSP 9632
Product
Description
Download PDF
HDSP 9632
Manual for HDSP 9632
version 1.3, 12/2007
Product Images
Back
