HDSP 9652
52-Channel PCI Card with ADAT and SPDIF I/O
HDSP 9652
Products
HDSP 9652
HDSP 9652 offers 3 x ADAT optical I/O, ADAT-Sync In, SPDIF I/O and word clock I/O. On top, there are 2 MIDI I/Os and TotalMix, a DSP-based real-time mixer/router, with hardware-calculated level metering and complete MIDI remote capability.
Connectivity and Features
3 x ADAT I/O
1 x SPDIF I/O
2 x MIDI I/O
1 x Word Clock I/O
1 x TotalMix FX
1 x ARC USB
The HDSP 9652 also supports Expansion Boards (EXB). Two internal ADAT inputs and two internal ADAT outputs allow you to realize up to 16 analog inputs, 16 analog outputs, or up to two TDIF ports directly inside the computer.
Thanks to its unique Zero CPU Load technology Hammerfall DSP guarantees highest performance and lowest latency together with full flexibility!
The HDSP 9652's Secure BIOS Technology allows to perform hardware updates via software/driver without any risk.
Free Software for all RME Audio Interfaces
Features
The HDSP 9652 provides unique features:
  • 3 x ADAT digital I/O, based on RME's reliable Bitclock PLL
  • 1 x SPDIF digital I/O, based on RME's reliable DIGI96 technology
  • 1 x Breakout cable for coaxial SPDIF operation
  • 1 x Word clock I/O (BNC) on included expansion board
  • 1 x ADAT Sync In (9-pin D-type) for sample accurate transfers
  • 2 x MIDI I/O, 32 channels high-speed MIDI via breakout cable
  • DIGICheck, RMEs unique metering- and analyse tool
  • HDSP Meter Bridge: freely scalable level meters, peak- and RMS calculation directly in hardware
  • TotalMix FX: 1352 channel Mixer with 40 Bit internal resolution
  • S/MUX poured in hardware: 12 channels 24-Bit/96kHz for record and playback on ADAT optical
... and numerous other features found already in the Hammerfall series. And all this for an unbeatable price!
Accessories
  • TEB - TDIF Expansion Board (no longer available)
  • Digital breakout cable, SPDIF (BOHDSP9652)
  • MIDI breakout cable (BOHDSP9652MIDI)
Specs
HDSP 9652
  • Supported sample rates: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, variable
  • 8 buffer sizes/latencies available: 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms, 186 ms
  • ASIO zero CPU load technology: 0 (zero!)% CPU load when using ALL 52 channels!
  • All settings changeable in real-time
  • Clock modes slave and master
  • Automatic and intelligent master/slave clock control
  • Enhanced Mixed mode: All inputs and outputs simultaneously operational
  • Unsurpassed Bitclock PLL (audio synchronization) in ADAT mode
  • Enhanced Zero Latency Monitoring for latency-free submixes and perfect ASIO Direct Monitoring
  • DIGICheck, the ultimate measurement, analysis and test tool
  • Input 3 x optical (TOSLINK), 1 x coaxial (RCA), 2 x MIDI, word clock (BNC)
  • Input format SPDIF, AES/EBU (Consumer, Professional), ADAT® optical
  • Output 3 x optical (TOSLINK), coaxial (RCA), 2 x MIDI, word clock (BNC)
  • Format output SPDIF, AES/EBU (Consumer/Professional), ADAT® optical
All specifications are subject to change without notice.
Back
Drivers
HDSP 9652
Mac OS X
Release date
Download
TotalMix FX 2.x Mac, Installer, latest version
TotalMix FX V 2.03 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.03 or 1.991, when using an older or not yet updated driver package.
Release date
2026-05-29
TotalMix FX Mac, v 1.99 (single file download)
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Download
tmfx_mac_199.zip
TotalMix Remote Mac
Release date
2024-10-17
Windows
Release date
Download
TotalMix FX Windows 32 bit, v1.99 (single file download)
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
TotalMix Remote Windows
Release date
2024-10-17
Windows 10
Release date
Download
TotalMix FX 2.x Windows Installer, latest version
TotalMix FX V 2.03 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.03 or 1.991, when using an older or not yet updated driver package.
Release date
2026-05-29
TotalMix FX Windows 64 bit, v199 (single file download)
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
Release date
2025-05-05
Windows 11
Release date
Download
Release date
2026-05-29
TotalMix FX Arm64 v 1.99 (single file download)
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2025-05-05
Release date
2025-05-05
Flash Update
Release date
Download
Windows Flash Update Tool (02/2009)
UpdatesPCI and CardBus card to hardware revision 17/55 HDSP 9652 to 108, HDSP 9632 to 155, HDSP MADI to 207 and AES-32 to 234. Flash Update Tool for Windows 2000/XP/Vista/7/8/10.
Attention: Users of HDSP PCI Rev. < 1.8 and the flat HDSP CardBus (15-pin connector) please carefully study the included readme before performing the flash update
Release date
2015-10-12
Download
fut_wdm_dsp.zip
Mac OS X
Release date
Download
Mac OS X Intel (10.4.8 or up) version of the PPC driver 1.6c for Hammerfall DSP System
Also supports HDSPe PCI Card and ExpressCard with Digiface, Multiface and RPM. Version 1.73. See readme.txt for important notes!
Release date
2008-06-22
Download
hdsp_173_x86.gz
Windows
Release date
Download
Release date
2015-10-12
Download
fut_wdm_dsp.zip
Windows 10
Release date
Download
x64 / Arm 64 bit driver for Windows 10 and up, HDSPe Series
Driver for Windows 10 / 11, Intel x64 and Arm, version 4.62. Supports Intel Windows 10 or up 64 bit and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
Release date
2026-01-28
WDM/ASIO driver for HDSP/HDSPe cards/systems
WDM, WDM-KS and ASIO. Version 4.50. Windows XP SP3 / 8/10/11, not Windows 7. Supports all HDSP and HDSPe cards/systems except HDSPe MADI FX.
Release date
2025-01-16
Windows 11
Release date
Download
Release date
2026-01-28
Release date
2025-01-16
Windows 7
Release date
Download
WDM/ASIO driver for HDSP/HDSPe cards/systems - Windows 7
WDM, WDM-KS and ASIO. Version 4.36. Windows XP SP3 / 7/8/10. Supports all HDSP and HDSPe cards/systems except HDSPe MADI FX.
Release date
2020-12-10
Windows 8
Release date
Download
Release date
2025-01-16
Windows XP SP2
Release date
Download
Release date
2025-01-16
Release date
2020-12-10
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Windows 10
Release date
Download
DigiCheck NG Windows
Release date
2025-05-26
Windows 11
Release date
Download
Release date
2025-05-26
Windows Vista
Release date
Download
DIGICheck 4.53 (Works with all RME cards, except HDSPe RayDAT and AIO)
Stereo Level Meter, Multichannel Level Meter, Global Level Meter, Spectral Analyser, Vector Audio Scope, Correlation Meter, Totalyser, Bit Statistic & Noise, Global Record. ASIO support, multi-client operation, display of +dBFS levels, display of playback data, K-system, free reference/scale, third colour. New: Hardware Level Meter. RMS Slow and RLB weighting filter. Optional Correlator. Level meters vertical/horizontal. Presets with hotkeys. Support for Fireface 400, newer Fireface 800 drivers, HDSP series WDM driver. Record functionality Global Record. Compatible to HDSPe PCI and HDSPe MADI/MADIface
Release date
2008-09-02
Download
dc_453.zip
Windows XP SP2
Release date
Download
Release date
2008-09-02
Download
dc_453.zip
DIGICheck 2.90 (Works with all RME cards except HDSPe series)
DIGICheck for Windows 98/ME/NT/2000/XP, Version 2.90 from 4.12.01
Release date
2001-12-04
Download
digichck.zip
Back
Manuals
HDSP 9652
Product
Description
Download PDF
HDSP 9652
Manual for HDSP 9652
version 1.3, 03/2010
Product Images
Back
