HDSPe AIO
38-Channel PCI Express Card with Multi-Format I/O
Connectivity and Features
For the first time, all inputs and outputs are simultaneously operational, even SPDIF (phono) and AES/EBU (XLR). Additional hi-quality analog inputs and outputs can easily be added by favourably priced expansion boards. Of course TotalMix, the unsurpassed flexible routing mixer and SteadyClock, RME's sensational clock technology with maximum jitter suppression of external clock signals, are on board too. HDSPe AIO also supports the optional TCO for synchronization to timecode (LTC/video). All this combines into a professional 'soundcard' that the world has not seen before.
HDSPe AIO is the newly developed PCI Express version of the HDSP 9632. A newly developed genuine PCI Express core consequently takes full advantage of the new format, achieving significant performance gains in multitrack audio and lowest latency. Thanks to RME's secure flash update technology, firmware improvements, adjustments, and bugfixes can be installed easily at any time.
Features
The HDSPe AIO provides unique features:
- Balanced* stereo analog in- and output, 24-bit/192kHz, > 112 dB SNR
- Optional analog expansion boards with 4 balanced in- or outputs
- All analog I/Os capable of 192 kHz, constant number of available channels
- 1 ADAT digital I/O, supporting 192 kHz via S/MUX4 operation
- 1 SPDIF digital I/O, 192 kHz-capable
- 1 AES/EBU digital I/O, 192 kHz-capable
- 1 Stereo headphone output, separate DA-converter and playback device
- So up to 18 inputs and 20 outputs can be used simultaneously!
- 1 MIDI I/O with 16 channels of hi-speed MIDI via breakout cable
- DIGICheck, RME's unique metering- and analysing tool
- TotalMix: 760 channel Mixer with 42 bit internal resolution
- Native PCI Express - no PCI to PCI Express bridge used
* The HDSPe AIO ships in a basic version with analog RCA/phono breakout cables (headphone: TRS jack). Therefore all analog I/Os are unbalanced. An analog XLR breakout cable is available as option (headphone: Neutrik TRS locking jack), turning analog into balanced mode.
HDSPe AIO includes SteadyClock (TM), RME's own clock technology, combining professional features like maximum jitter suppression at full varipitch capabilities and software controlled sample rates.
Included software:
DIGICheck for Windows: Spectral Analyser, professional level meter for 2, 8, or 20 channels, Vector Audio Scope, various other audio analysis tools.
Accessories
- optional: TDIF Expansion Board (no longer available)
- HDSPe AIO: Analog breakout cable, balanced (BO9632XLRMKH)
- HDSPe AIO: Analog breakout cable, unbalanced (BO9632CMKH)
- HDSPe AIO: Digital breakout cable, SPDIF (BO9632)
- HDSPe AIO: Digital breakout cable, AES/EBU & SPDIF (BO968)
Word Clock Module (WCM)
Works with: HDSPe RayDAT, HDSPe AIO, HDSP 9632
The Word Clock Module (WCM) provides a galvanically isolated word clock input and two word clock outputs (BNC connectors). Both outputs have their own driver stages, providing an extremely low jitter signal. A push switch activates 75 Ohms termination for the hi-impedance input. SteadyClock, part of the PCI card, guarantees an excellent performance in all clock modes. Its highly efficient jitter suppression refreshes and cleans up any clock signal, and provides it as reference clock at the two outputs.
Installation is done in a convenient manner using the supplied bracket. No PCI slot on the motherboard is required. The module is internally connected via a 10-pin connector and a flat ribbon cable to the PCI card. Thanks to several LEDs (power, termination, LOCK) and the highly integrated concept of installation, first operation and usage are simple even for the inexperienced user.
More information could be found in the HDSP 9632 WCM manual.
AI4S-192 AIO and AO4S-192 AIO: 4-Channel analog I/O modules with 192 kHz support
Works with: HDSPe AIO, HDSP 9632
These options for the HDSP 9632 and HDSPe AIO are analog expansion boards, designed as bracket with 4 stereo TRS jacks each. AI4S-192 AIO provides four servo-balanced inputs, AO4S-192 AIO provides four servo-balanced outputs. With this a maximum of 6 (including the stereo I/O of the card) inputs and/or outputs can be achieved.
The converters offer the same performance as the on-board stereo analog I/O of the HDSPe AIO: up to 192 kHz, balanced connection and the choice of three different reference levels, selected in the Settings dialog.
Both modules can be used single or in combination. The display of the channels in TotalMix changes accordingly.
Note: AI4S-192 and AO4S-192 (without the suffix AIO) do work only with the HDSP 9632. The current Expansion Boards with the suffix AIO work with both cards.
More information could be found in the manuals:
Specs
HDSPe AIO
- 1-Lane PCI Express Endpoint device (no PCI Express to PCI Bridge), revision 1.1.
- 2.5 Gbps line speed
- Packet-based full-duplex communication (up to 500 MB/s transfer rate)
- Supported sample frequencies: Internally 32, 44.1, 48, 64, 88.2, 96, 176.4, 192 kHz. Externally 28 kHz - 200 kHz
- 8 buffer sizes/latencies available: 0.7 ms, 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms
- All settings changeable in real-time
- Automatic and intelligent master/slave clock control
- Enhanced Mixed mode: All inputs and outputs simultaneously operational
- TMS (Track Marker Support): Supports CD/DAT start-IDs and the read out of CD subcode
- Unique status windows for record and playback, showing mode and sample rate
- DIGICheck, RMEs unique metering and analysing tool
- Digital inputs and outputs ground-free transformer coupled
- 3-stage hardware level control for analog inputs and outputs
- Balanced analog input and output, DC-coupled signal path
- 192 kHz / 24-bit converters. SNR 112 dB RMS unweighted, 115 dBA
- Maximum input and output level (0 dBFS @ HiGain): +19 dBu
- Low impedance headphone output (30 ohm), separate DAC and playback device
- Super low jitter design: < 1 ns in all clock modes
All specifications are subject to change without notice.
Drivers
HDSPe AIO
TotalMix FX V 2.02 and 1.991 for Mac OS. The installer offers a convenient update process for TotalMix FX wth the latest version 2.02 or 1.991, when using an older or not yet updated driver package.
TotalMix FX V 1.99. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
TotalMix FX V 1.99 for Windows, 32 bit version. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
TotalMix FX V 2.02 and 1.991 for Windows x64 and ARM. The installer offers a convenient update process for TotalMix FX wth the latest version 2.02 or 1.991, when using an older or not yet updated driver package.
TotalMix FX V 1.99 for Windows x64.. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Installation: Exit TotalMix FX (right click systray icon) and copy the new version into C:\Program Files\RME\Fireface or \MADIface, overwriting the old file. If there is no such directory then you need to use the TotalMix FX 32 bit file.
TotalMix FX V 1.99 for Windows Arm 64 bit. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Updates HDSPe MADI to firmware version 33/210, HDSPe PCI and HDSPe ExpressCard to 20, RayDAT to 18/207, AES to 11/204, MADIface to 23, AIO to 14, AIO Pro to 23/108.
Now also includes the DriverKit firmware versions:
HDSPe MADI to firmware version 35/216, HDSPe PCI and HDSPe ExpressCard to 21, RayDAT to 20/210, AES to 13/207, MADIface to 24, AIO to 201, AIO Pro to 26/110.
Updates HDSPe MADI card to firmware version 33/210, HDSPe PCI and HDSPe ExpressCard card to 20, RayDAT to 18/207, AES to 11/204, MADIface to 23, AIO to 14, AIO Pro to 23.[nbsp]Windows XP SP2 / 7 / 8 / 10 / 11. Supports all HDSPe cards/systems! Now also includes DriverKit compatible firmware versions.
Version 4.25, for macOS 11 and up. Supports Intel and Mx. See readme for installation notes.
Supports 10.9 up to 10.15. See readme.txt for important notes! Version[nbsp]4.17. Also supports HDSPe PCI Card and ExpressCard with Digiface, Multiface and RPM.
Mac OS X SL (10.6) Intel driver for HDSPe series (MADI, AES, RayDAT, AIO, MADIface, Multiface, Digiface, RPM). Supports 10.5 in 32 bit, 10.6 in 32 bit and 64 bit. See readme.txt for important notes!
Version 2.67. Supports DIGICheck. See readme.txt for important notes!
Driver for Windows 10 / 11, Intel x64 and Arm, version 4.62. Supports Intel Windows 10 or up 64 bit and Windows 11 Arm systems, with both WDM and ASIO. Updated installer. See readme for details.
WDM, WDM-KS and ASIO. Version 4.50. Windows XP SP3 / 8/10/11, not Windows 7. Supports all HDSP and HDSPe cards/systems except HDSPe MADI FX.
WDM, WDM-KS and ASIO. Version 4.36. Windows XP SP3 / 7/8/10. Supports all HDSP and HDSPe cards/systems except HDSPe MADI FX.
Universal binary, runs natively on Intel and Mx machines. DigiCheck NG V 0.93 requires macOS 10.13 (High Sierra) or up.
